Merseyrail issues 18-07-19 onwards
Polarbear
24 May 2008
Birkenhead
Merseyrail's Northern Line has been closed for most of yesterday, and all of today, due to power supply issues. Although It's happened before, I don't recall things being so serious that the line has had to be closed for more than a couple of hours at any time.
Does anyone happen to know what the root cause of the problem is?
Polarbear
24 May 2008
Birkenhead
Sorry, yes. It’s only part of the Northern Libe that’s out. Rail replacement buses are operating.
Y Ddraig Coch
1 Nov 2013
Big festival in Sefton Park Liverpool this afternoon as well.
Any train issues could be problematic as I expect it will be the usual Friday rush, plaus the extra 1000's travelling to the festival.
Matt_pool
9 Nov 2016
This has been causing massive overcrowding on Northern and other services into Lime Street during rush hour.
Commuters don't want to sit on a rail replacement bus that takes 40+ minutes when they can squeeze onto a Northern Rail 156 for 12-15 minutes instead.
Thank God they have been using 156's (albeit only 1 unit!) over the past couple of days, because if they had been Pacers or 150's people, like myself, would have been unable to board the train at West Allerton or Mossley Hill and we would have been late for work!
It didn't help on Thursday that the guard of the 156 I caught allowed 5 bikes squeeze on into one end of a carriage!
To be fair the Class 156 van area is perfectly suitable for 5 bikes, probably more. If they were on first, the guard perhaps didn't know he'd be full and standing from Hunts Cross.
Saperstein
28 May 2019
Chester
Update: Disruption extended until end of service Monday 22 July.
UPDATE - Hunts Cross line disruption extended to Monday
UPDATED - Disruption extended until end of service Monday 22 July.
Due to a cable fault on the Hunts Cross line, the power supply to the third rail has been severely reduced preventing trains running between Liverpool Central and Hunts Cross.
Unfortunately due to the complexity of the fault and the work required to rectify it, Network Rail have advised that services will continue to be suspended all day Monday 22 July, until start of service on Tuesday morning (23 July).
If the fault is rectified before this time, we will resume a normal train timetable as soon as possible.
Passengers are advised to check merseyrail.org or @merseyrail on Twitter before they travel.
Source: Merseyrail app.
Saperstein.
Skie
22 Dec 2008
Based on the recent image tweeted by network rails lime street account, it looks like they are replacing a fairly large section of cable.
Saperstein
28 May 2019
Chester
Shame they can’t get a few DMU’s in to deputise as the problem doesn’t seem to be lineside?
I guess that’s one drawback of an all electric fleet, but that said there would probably be issues of crew signing traction/routes.
Saperstein.
modernrail
26 Jul 2015
I would be interested to know what the likely causes of this level of damage to a high voltage cable are if anybody has experience of such things.
aleggatta
28 Sep 2015
I'm very puzzled as to the need to joint multiple locations, sounds like the cable has been left to deteriorate to a point of unusability. The standard 11kv installation at the hospital I worked at featured ducts buried in sand, with concrete slabs on top, and whilst I can appreciate you don't necessarily need the ducts, but for a cable to have issues in such a massve way either says to me manufacturing error, installation error or damage during transit.
urbophile
26 Nov 2015
Saperstein.
They wouldn't be able to run into Central, so you'd still need replacement buses from Brunswick.
Elecman
31 Dec 2013
Lancashire
Possibly using an old method but well trusted way of locating an underground cable fault, split the cable at the approximate Halfway point see which half is faulty, then repeat halfway on the faulty section and again until you get to a reasonable length of cable to replace.
Harryn9000
15 Jan 2010
they must either be old cable or fault with the cable. as most of the cable has been replaced fairly recently across the network
aleggatta
28 Sep 2015
That method is virtually redundant with the fault tracing equipment available, although given this is NR and not a DNO who knows
DNO: distribution network operator
Elecman
31 Dec 2013
Lancashire
Trust me DNOs still use this technique, reflectance distance measuring isn’t always suitable but is widely used
Saperstein
28 May 2019
Chester
Yep all back to normal :) and the say it, see it, sorted messages are back (it was automated messages about the disruption over the weekend all over the network.)
Saperstein.
