markymark2000
I am wondering if anyone can help with this. I note that Manchester Metrolink has the most strange turnaround sidings using only trailing points which mean that a tram which is changing directions must do so on a normal line, then head into the siding before joining the correct running line. What is the logic of this? Isn't the point of turnaround sidings that the tram can sit in the siding then the driver switches ends then heads back the same way? That operation increases capacity of the line as a tram isn't blocking a main line while the driver switches ends. The only benefit that I can see of Metrolink having their points and sidings in this way is that there is slightly less cost. Less points to build and maintain. Examples of these can be found on Warren Bruce Road in Trafford Park and between Velopark and Etihad Campus.
Wouldn't siding layouts such as those at Cornbrook (for the one near Etihad Campus) or Timperley (for the one at Warrn Bruce Road) make more sense for these areas?
Etihad Campus siding: https://www.google.co.uk/maps/@53.4835685,-2.1956162,140m/data=!3m1!1e3
Warren Bruce Road Siding: https://www.google.co.uk/maps/@53.4686708,-2.303983,114m/data=!3m1!1e3
