MMI and Police :S
Discussion in 'Railway Jobs & Careers' started by James_smalling, 21 Jan 2020.
  1. James_smalling
    James_smalling Member
    26
    6 Feb 2019
    Hey guys, long term fan of the forums.
    I just wanted to ask really if there were any ex PC's that have made it to becoming a train driver, that had any advice on what to say/not to say in regards to the MMI. Especially if you have examples relating to safety critical situations in a covert role or examples which are not cleared to give due to levels of vetting and the secrecy act.
    What would you advise?
    Rail Forums
  3. Stigy
    Stigy Established Member
    3,262
    6 Nov 2009
    Hi, and welcome.
    There are literally hundreds of ex Police who have transitioned over to drivers. I’d say personally as far as the MMI goes, you know what you can and can’t share, so just go with any situation which you know or believe will be suitable. You don’t have to be specific to dates/times/names etc (in fact, you certainly shouldn’t go in to that much detail as it’s not required and will be verging on waffling really) so this shouldn’t really be an issue at all.
  4. Mag_seven
    Mag_seven Established Member
    5,697
    1 Sep 2014
    here to eternity
    What is an MMI?
  5. James_smalling
    26
    6 Feb 2019
    Appreciate that Stigy!
    THE most helpful member of this forum!
  6. James_smalling
    26
    6 Feb 2019
    The multi modal interview I think is what it stands for. It's the interview you sit at your day 2. If you pass it you move onto the DMI Driver manager Interview
  7. dctraindriver
    dctraindriver Member
    250
    9 Jan 2017
    Go back and look at the skills you used before you specialised, you should have plenty.
  8. Teddyward
    Teddyward Member
    389
    3 Oct 2017
    Thurrock
    And remember it’s about what you did in the situation.
  9. heedfan
    heedfan Member
    135
    4 Oct 2017
    You will have no shortage of situations that could be good answers for the MMI as a PC. Do your research, look at the answer strands and have at least two possible scenarios for each question. The questions are well publicised on this forum and elsewhere. Best of luck to you.
  10. Daydr3am3r
    Daydr3am3r Member
    368
    7 Dec 2018
    PM me if you want mate :)
  11. JRE
    JRE Member
    20
    11 Nov 2016
    Hi Daydr3am3r,
    I'm in the same position as James_smalling above. I can't PM you though, as I don't have the functionality to! I think I have to post a few more messages to the forums before I can do that?
    I'd appreciate any and all advice though, as I have my Driver interview soon.
    Thanks for any help,
    JRE.
  12. Choochoo0001
    Choochoo0001 Member
    26
    28 Jun 2019
    Morning mate.
    My advice would be to cross reference your answers with the driver Non Technical Skills.
    https://www.theopc.co.uk/files/Which NTS are most important for train drivers - Final.pdf
    With each answer, you should be looking to try and demonstrate as many of these as you can.
    For example, they asked me to provide an example of when I performed a role that I think is similar to that of a train driver’s - and I used being placed on a custody watch, observing a detainee that posed a risk to themselves.
    Then I talked about (for example); “following rules and procedure” (PACE) and mentioned having to build a rapport with the detainee, but taking care not to ask or talk about the offence they were arrested for as this could constitute a non PACE compliant interview and could harm the case.
    Also “maintaining concentration” as it is boring sometimes just watching a detainee sleep all night
    Etc etc.
    Your answers don’t have to be “Gucci” and sound like excerpts from a cop movie, they just have to demonstrate all the non technical skills they are hoping to see. Focus on ensuring any answer, no matter how boring the Setting, hits lots of the NTS and you’ll be okay.
  13. Choochoo0001
    Choochoo0001 Member
    26
    28 Jun 2019
    ALSO - Avoid police jargon and acronyms. Avoid quoting legislation and sections of legislation.
    All these things obviously come as natural to police and ex-police, but these interviewers may have NO idea what any of the jargon, acronyms or legislation even mean.
    Treat every interviewer like a Day One probationer at training school. They have no prior knowledge and will need everything broken down to them.
    If you mention a piece of legislation, explain what that means to you, how it affects the scenario you’re talking about and how you worked within those confines - otherwise, there’s a risk that they’ll miss the relevance of how you hit certain NTS.
    (For example, the scenario I talked about earlier - I explained that PACE allowed for a detainee to be interviewed under caution, and explained what that meant, and that they could obtain free and impartial legal advice prior to being interviewed. Hence being asked questions about the offence in their cell overnight could potentially be a breach of that - so I took care not to talk about the offence at all)
  14. MostlyHarmless
    MostlyHarmless Member
    709
    1 Mar 2018
    Just to add that your examples don't have to be work related; one of the questions that seems to come up quite frequently (and I had it ) is 'tell me a time where you had to persevere to achieve something' or words to that effect. I told them about the time I ran a marathon for the first time (and I really did have to persevere!) but it could equally be studying for a qualification etc.
  15. Stigy
    3,262
    6 Nov 2009
    Thank you :E:E
    Good luck with it, you’re in the right place to get all the advice you need.
  16. Emma99
    Emma99 New Member
    4
    17 Jun 2019
    Hi James,
    I’m a Police Officer about to make the move to a train driver. Currently in a high vetted role and so couldn’t use any examples from this area of my work history. I cast my mind back to a being response team officer and used all examples from there. It doesn’t matter how old the examples are.
    Good luck!
  17. Stigy
    3,262
    6 Nov 2009
    I see what you’re saying, but worth emphasising that you need only be brief in any examples, so unless you’re going to give examples about national security or the like and would need to be descriptive for it to make sense, you could probably use any example you like. Just leave out names/dates/times/locations, or change the location/date/times etc to suit. It’ll have the same effect and you’ll be able to answer the ‘probing’ questions because it’ll be a truthful example.
Share This Page
