MML Electrification: progress updates
richieb1971
28 Jan 2013
Any dates yet for Sharnbrook to Wellingborough being 4 track throughout?
Are we waiting for the Wellingborough platform to be completed? I would imagine that is taking precedence over the track since I believe its wise to do the platform first.
August is when I believe it will all be done and wired.
Aictos
28 Apr 2009
Any news on when Platform 4 at Bedford will be wired up and also is there any timescales for the work to be done which will make both Up and Down Fast lines bidirectional within the station limits as I believe has already been discussed here?
59CosG95
18 Aug 2013
Between Peterborough & Bedlington
Of possible, passable interest - SPL Powerlines (main OLE contractor for MML) are looking for a Graduate Environmental Advisor - based in Derby.
While the job role is neither here nor there and the grand scheme of things, it's encouraging to note the location.
Bob Buckler
12 Feb 2018
I notice that at the new crossovers south of Wellingborough there is no connection from Down Fast to Up Fast to access Platform 3.
I suppose that if the Corby Electrics are going to use Platform 1 and then cross to the slow line north of the station,then it's not essential.
However, I assumed that all four lines would be connected as at all the other crossovers between Bedford and Kettering.
I'm guessing that's because the crossover in question would have to be where the curve tightens south of the station, and would result in a speed restriction and/or a maintenance headache.
Aictos
28 Apr 2009
We don't have any source maps to make the update from, so it'll have to wait until trains start running at the weekend.
Fair dues but how did Open Train Times manage? Also when you do the update, will you update Redhill too as that has a construction label yet I’m sure trains use it.
takno
Presumably somebody has furnished OTT with a map. The Sussex and Wessex area maps on Traksy were extensively edited over the holiday period, including the removal of the construction label on Redhill station.
38Cto15E
1 Nov 2009
15E
I assume that we are now back in the 'Record Books' for the longest 4 track section in the UK? St Pancras to Glendon.
Aictos
28 Apr 2009
Ahh no worries, glad to see the updates.
Jamesrob637
12 Aug 2016
Kettering station is 71 miles away from St Pancras. Guess the junction may be closer to 75?
Flying Phil
18 Apr 2016
I have not yet seen any confirmation that there will, at least, be electrification from Glendon to Market Harborough for the substation at Braybrooke to be connected. The last information was that a financial case was being sought?....Whilst all the workers and plant are nearby, it must be the most sensible option.
sharpley
18 Aug 2018
Merle Haggard
20 Oct 2019
Northampton
1C98 0731 Derby St p was booked bi-directional goods line calling at Wellingboro' Plat 3.
Now both the former goods lines are back in use, but Plat 4 at Wbro' not yet open, how will this run? Can it run up the down slow?
Merle Haggard
20 Oct 2019
Northampton
Just under 74 miles. But now you theoretically can have three Up lines as the Down slow is bi-di.
Kettering North Junction (we knew as Glendon) is MP74.00 but I don't think that St Pancras Midland Main Line is now 00.00. Different alignments between Bedford & Wellingboro' though; depends how it's defined, but if the Sharnbrook diversion counts as the same route, then one could argue that the West Coast is 4 track to Crewe by counting alternative routes...
Going by the OpenTrainTimes map lined above, the bi-directional line is the one you would expect to be the Down Slow. The map doesn't give a name for it but it hasn't been a Goods line since the Leicester re-signaling 30+ years ago - if not longer. A line designated as Goods can't carry passenger-carrying trains except under special arrangements.
Merle Haggard
20 Oct 2019
Northampton
Yes, sorry, I meant that the train I mentioned was previously booked on the bi-directional line but my question was can it run 'up' on what is now the 'down' slow, only possible if that line is bi-directional to Sharnbrook?
Once the Higham branch services ceased (and even they only used Wellingboro' - Irchester J.) the slow lines were used mainly for freight and the train I mentioned, introduced about 1999, was the first regularly timetabled passenger service to be booked to run on the slow lines Kettering S J to Bedford, possibly ever. I've travelled on passenger trains that ran on the slow lines at odd times over the years (certainly since 1968) when problems occurred on the direct route so I accept my terminology was loose, but of course the purpose of the Sharnbrook deviation was to provide an easier (in terms of gradients) route for goods trains, hence 'former goods lines'.
Once the Higham branch services ceased (and even they only used Wellingboro' - Irchester J.) the slow lines were used mainly for freight and the train I mentioned, introduced about 1999, was the first regularly timetabled passenger service to be booked to run on the slow lines Kettering S J to Bedford, possibly ever. I've travelled on passenger trains that ran on the slow lines at odd times over the years (certainly since 1968) when problems occurred on the direct route so I accept my terminology was loose, but of course the purpose of the Sharnbrook deviation was to provide an easier (in terms of gradients) route for goods trains.
Yes the line that is probably called the Down Slow is bi-directional as far as Sharnbrook, as shown by the signals for both directions on the map linked from post 3310. A train calling at Wellingborough can't use the new Up Slow until Platform 4 is in use.
The eastern pair of tracks was indeed originally designated as Goods over most of their length, which allowed such things as multiple goods trains stacked nose to tail under permissive block regulations (with the odd pile-up on a foggy day). There is evidence of this for example in the layout of the Luton station buildings, where the Slow platforms were obviously added later, and Loughborough and Chesterfield which still only have three platforms. Over the years sections of them were converted to passenger use, especially further south as commuter traffic became more important and freight declined. But many lines in the area re-signaled under Trent powerbox in the late 1960s remained as Goods until the replacement of that box in the 2000s.
More recent practice is to provide for passenger use on all lines unless there's a very good reason to do otherwise, and any Goods lines that existed in the areas of the West Hampstead (~1980) and Leicester (~1988) re-signaling would have been converted to passenger use at that time even if very few passenger trains actually used some of them.
Pedantically, it is only continuously four tracked* north of Carlton Road Junction, a couple of miles north of St Pancras.
* whilst there are 4 tracks (and often more) for just over a mile south of Carlton Road Junction to Dock Junction North, the ‘slow’ pair are routed to the Thameslink core. It is not possible to run parallel moves from the ‘slow’ pair to/from St Pancras.
I could however start an even more pedantic argument to say that there are still four tracks, just that two of them go to the low level platforms. Their separation distance is less than the ones over Sharnbrook...
