cjmillsnun
- Joined
- 13 Feb 2011
- Messages
- 3,254
That may be easier as they won’t have to remember what the last signal was.If drivers feel overloaded now, just imagine when ETCS is rolled out
Is there any system by which those designers can get cab rides to give them a better idea of how the real world works ?Whilst, thankfully, the railway is already so safe that even if a driver makes a mistake due to not fully understanding the information presented or due to distraction from "all those bleeding flashing lights and doodads!" that the chances of a serious disaster are fairly remote but I do wonder if the industry and specifically those that design the cabs and the UI of the computers that go into them are fully alive to such issues and give them the respect they deserve?
I just have one query with your initial statement. Why is the 'Driver' screen considered safety critical in showing the power and brake position? I would have thought physically having your hand on the controller would tell you where the position of the handle was, or is this a similar thing as to electrostars where they have the seemingly useless 'power usage' info available to drivers that doesn't seem to be of any real aide to driving. I'm not familiar with these units so it could well be that the speedo is on the drivers screen and I would be suitably disappointed with the designers for allowing an alarm to cover the speed indication on a unit.Have a look at a picture of a class 710 cab, it's just overload.
For a case in point of what distractions are possible, on one class of our new units some bright spark has decided to perform a software update that means that any time some passenger presses a 'call for aid' (every few minutes now on a Friday/Saturday night) the main TCMS ('driver') screen that displays the drivers power and brake position, and is safety critical, suddenly reverts to a page that only shows the PA system. The driver doesn't even operate the PA on our units, we have guards for that. This is a recent software change and would be a huge distraction at certain critical moments considering the change in screen to something useless is also accompanied by lights and a loud audible alarm - not what you want when you're a coach length from a buffer stop.
I'd also add that some specific brake / power steps are required by the TMS and also required by driving policies.
Our running brake tests are 60% minimum. So having a readout is almost essential to ensure its been carried out at the right percentage.
Any of our slow speed modes need to use less than 33%
Having some kind of visual indication helps.
Think some people want to hark back to the days of two leavers and a brake cylinder pressure gauge.
If you get overloaded by a class 710 cab then you really shouldn't be driving a train.
Exactly this - normally there's not a great deal going on, and that includes our wonderful CAF units, but the potential for intrusive alarms at critical moments gets given little thought when these things are designed.The cab on its own perhaps but when you are approaching a red at night and someone pulls a passenger alarm and then there is an audible alarm, a visual alarm on one screen, a bright yellow or red readout on another screen, a flashing lamp on the desk and a live CCTV screen on a third suddenly it becomes very easy to forget or be distracted from the signal.
On the 378s we have dark mode. When selected, after the train goes above 4mph the TCMS screen turns off and dark. Is that what you mean, or have a dark mode that switches to black background and white text so you can still see the screen?I don't think modern cabs are overload, I'm confused by the comments about drivers relying on the screen to tell them what position the PBC is in, it's normally possible by feel and you can tell if your train is slowing down or speeding up anyway.
However the one thing I long for on Mitrac (Electrostar TMS) is dark mode!
Our iPads for DAS/TAS have dark mode, it surely wouldn't be too hard to have dark mode on the TMS?
As a result most drivers turn the screen off completely once it gets dark, so that they can actually see out the windscreen in front of them.
I mean more like dark mode on newer phones and laptops. All information visible but doesn't blind you. Our Electrostars also have the ability to turn off the screen in the same way.On the 378s we have dark mode. When selected, after the train goes above 4mph the TCMS screen turns off and dark. Is that what you mean, or have a dark mode that switches to black background and white text so you can still see the screen?
In regards to the PBC position, the newer Aventra units have a smooth PBC and Brake (345), although for ARL (710), they pushed Bombardier to make the brakes remain as brake steps but the power is "un-notched". I don't drive them myself but I can understand that it'd be harder to work out where the PBC is placed.
This probably explains the jerky braking that I experienced on my first ride on a 195. Not been on many more but they have been okay.Even when they were brand new every CPBC felt different. They've not got better with a couple of years of use. I assume there's meant to be a certain element of friction in the movement through the arc to power and to brake, but some are completely free of friction to the extent that if you let go of the CPBC it will spring towards the extreme or minimum of whichever direction it had been applied (so the brake can be biased to spring back to release, and the traction power can spring towards maximum - both a bit dangerous really). Some others are so stiff to move that drivers have complained of arm & shoulder pain.
But when that happens you just stop. It doesn’t really matter precisely where, but you get the thing stopped and then deal with the issues. The same applies in any situation where you feel overloaded.
Probably an inexperienced driver or poor technique if it was 'jerky' - they can be very 'on/off' unless applied from the minimum setting.This probably explains the jerky braking that I experienced on my first ride on a 195. Not been on many more but they have been okay.
