Thats not a loco
Yes. But but I am not sure that a pacer can be given a better description
Be careful when you mention Pacers and "huge holes" in the same sentence.
It can get fertile minds working overtime
This is my nomination for the worst..of the worst. It was not a small build, as 117 were constructed between 1962-1965. The main problems with the class 17 (with its centre cab) were concerned with the 6 cylinder Paxman 6ZHXL diesel engines which were recorded as giving unsuitable performance in service, even after the refurbishments were carried out. Some of the fleet only had a working life of 5 years.
Withdrawals began in 1968 and the final one was withdrawn in 1971.
I suppose the 31s might be worse than 17s as there were more of them and they also had unreliable engines before being re-engined. Perhaps the 31s survived because there was a dwindling demand for smaller locos. I also heard once that Carlisle shed had 17s that were more reliable because they attended to the weak points more frequently (I seem to recall there was a fexible oil pipe that regularly perished - achilees heel).
Comparable, in size to the 17s, were the 20s which mostly ran around in pairs - I cannot believe that was the plan. The 17s had the benefit of a centrally located cab with a low body in front of the cab so the driver had a better view both ways ?. But the 20s had an engine that worked well - oh and they were a larger class that was more standard (shared components with 31s, 37s and 40s). The 17s would have been ideal as a replacement 08 especially where they have to go a long way from their home depot to a yard (08s have a very restrictive maximum speed).
In terms of engines everything went except locos with two basic types of engines :-
English electric 8CSVT(20s), 12CSVT(37s then 50s) or 16CSVT(40s) engines
OR
Sulzer 6LDA(24s, 25s, 26, & 27s) 8LDA(33s) or 12LDA (44s, 45s, 46s & 47s).
That says something about standardisation. But also a long time being improved/evolved. For example the 16 cylinder 16CSVT started life as about 1,000hp in the late 1940s (London Midland and Southern monsters), then became 2,000hp in the late 1950s (class 40s), but more power per cylinder (and so a better power to weight ratio) was then squeezed out of the 12 cylinder 12CSVT version(s) in the 1960s (class 37 at 1,750hp and then the class 50s at 2,800hp ?). That was decades of evolution.
Some of the above is not exact as its down to memory. And I cannot remember what the 31s got (but it was English Electric nnCSVT?). But you hopefully get the gist.
