My SCAAT results, any good?
ShorifAhmed
1 Jun 2016
Here is my results.
How did I do? Also, what score do I need to get?
27 Dec 2014
Here is my results.
What TOC is this for?
AFAIK most TOCs do the test as a written test, not computer based. My advice is to print off sheets and practice it that way. There's a print option in that program.
And always aim for 0 mistakes. The way I did it was to go as slow as I needed to get 100% accuracy and then keep practising ensuring you're always getting 100% accuracy.
Bromley boy
18 Jun 2015
100% this. Check with the TOC if the test is written or computerised. There is a book available to assist with written test practice. Make a conscious effort to slow yourself down, focus on accuracy first and then build up speed.
I was getting about five rows down on each page in the actual test and this was enough to pass.
27 Jan 2015
Without meaning to sound rude but those results are really bad. You need speed and accuracy to pass. I made the same mistake as you in the real test and failed. You don't need as many cells completed as you have done. 1000-1200 will be fine and you want to aim as close to 0 as possible on both targets emitted and targets missed.
Hope that helps and keep practising :)
ShorifAhmed
1 Jun 2016
Ahh, ok. Well it was the first time I dont this test so wasn't expecting to be good at all hehehehahaha lol. (lol)
And thanks for the advice.
Gonna be rollin' in some heavy pussy after I smash this test! :D:D:D:D:D:DD:D:D:DD:D
DunfordBridge
13 Apr 2013
Scarborough
Maybe a pussy is a nickname for some obscure kind of traction he expects to be driving if he is successful at application.
headshot119
31 Dec 2010
Dubai
My reaction to reading this O_O
25 May 2016
Leaving aside the comedy for just one moment...
How does this stack up? Preferably in terms of good pass or borderline or fail rather than any kind of pussy based scoring system...
HLE
27 Dec 2013
Re-read the post above about omitted targets. Go as slow as a mouse then pick up pace once you have no omitted or incorrect.
Is the SCAAT even used now?
25 May 2016
No idea, I have got the GBT nailed down to 54 rows no errors no omissions so figured I may as well have a go at SCAAT as well.
2000
27 Dec 2014
Noone here is going to be able to tell you the pass/fail mark or how well you're doing.
I'll repeat my original post - print the test off, do it with pen and paper and start off by going so slow you get 100% all the time. Then increase your speed afterwards.
Edit: the scaat is used by LU
