National to Enhanced question
WombleGuard
16 Dec 2019
Hello,
If you've passed all tests and MMI to national standard and you sit them again to try to reach Enhanced what happens to your national standard pass if you fail?
Kayle
15 Sep 2021
Reading
It depends on the score. If you fail enhanced, but still meet national standard pretty much nothing happens, but if you fail to achieve at least national standard then your previous scores will be overwritten unfortunately and you lose one of your lives.
NorthernTech
12 Apr 2021
Uk
As YingYing said, I believe a new attempt overrides any previous attempts. So if you pass to national standard still, but don’t hit the enhanced score that the TOC you are applying to accepts (the enhanced scores differ unlike the national standard), then you don’t lose a ‘life’. But if you fail, you lose one of your two lives and you cannot apply to any trainee driver job for the next six months. If you held a pass previously, it would be gone and you now just hold a fail. Then if you fail a second time its you out, no more chances to apply.
Duffman76
2 Jul 2019
So... What exactly is the increase in the 'benchmark' so to speak from standard to enhanced??
I was under the impression that some tests were scored on the candidates average on that particular day, as long as it was at a particular pass mark, unknown to candidates.
So what would enhanced be then?
WombleGuard
16 Dec 2019
Good question. It's all a bit of a dark art isn't it
NorthernTech
12 Apr 2021
Uk
There is no enhanced mark, there is only the National pass mark. The test marks don’t change as per the standard of the group, well the national pass mark does not. As for the enhanced marks, there are no set standards for this, the companies that want to only accept candidates who pass some of the tests at a higher pass mark, for whatever reason or skill this may be assessing, set the mark they want to accept. They are not the same ‘enhanced‘ level as far as I understand, and only some tests are asked to be at a higher mark, they sometimes ask for extra tests too. But one thing is for sure, you are unlikely to ever find out what the marks actually are, but if you read this forum, you will find out roughly what people think they got and whether they passed or failed.
Jaytrains
20 Nov 2017
What if you’ve passed at national level and you sit the dfft to get the enhance results, do your test scores start the 5 year validation again?
NorthernTech
12 Apr 2021
Uk
No idea! Sorry. But normally enhanced pass companies want more than a dfft test as far as I’m aware. Group Bourdon seems to be one test they need at a higher/enhanced level, although you could well have reached that level when you/someone passed it when doing the standard national tests, I’m that makes sense. It’s all rather confusing in some respects, would be so much easier if everyone knew what they were aiming at, but hey..
Jaytrains
20 Nov 2017
My mate passed at national and only had to sit the dfft and sjt to reach the enhanced level, but he failed the dfft
D Rivers
26 Nov 2019
Manchester
In addition to this, sorry to jump on your post. I passed tests to enhanced in 2020. These are valid for 5 years iirc.
If these lapse do I still have 2 lives?? Are they only fail lives? Could I in reality take them every 5 years if I keep on passing??
NorthernTech
12 Apr 2021
Uk
Yeah it’s only a fail that would lose a life. But your enhanced score for one TOC/FOC you passed with may not be acceptable to the enhanced score that another may want, as they may want an even higher mark. Enhanced scores are train company specific (I believe), not universal.
Stigy
6 Nov 2009
Bear in mind also that the length of time they’re valid isn’t based on them being national/enhanced. Different TOCs/FOCs allow passes for different lengths of time depending on their policy (from 1 to 5 years - usually 3 or 5 though).
D Rivers
26 Nov 2019
Manchester
Yeah I know. Northern is 2 which is a bit odd when some of the big boys ie. Xc are 5 years!
CreamNCookies
10 Aug 2018
Extract from an email I received from Northern states psychometrics are valid for 5 years;
"We would like to remind you that your Psychometric Assessment will remain valid for 5 years from the date taken."
Owen2323
18 May 2019
Say you're a qualified driver working at a TOC that 'only' required National level and apply for a job with a TOC that requires enhanced. Presumably you'd have to do the tests again or at least the one's you hadn't done to enhanced standard? What if you didn't pass even to the National standard.....?
Marshy
16 Apr 2018
@Owen2323 once your qualified, you don't have to do any psychometric tests again. You can go to any TOC (as long is your license is clean)
7 Jan 2010
I passed at National level 2 years back so still have a valid pass. I went for a Trainee Driver position with a TOC that required an enhanced pass and they allowed me to just do the VSE to make it enhanced. And even that they allowed me to do at home on my laptop.
Stigy
6 Nov 2009
You don't need a clean license to change TOC.
No, but some TOCs stipulate you do. I guess it depends on the nature of any incidents, and whether you can demonstrate how you’ve learned from them…if you get as far as interview?
ComUtoR
13 Dec 2013
Just like everything else. Meet the criteria for the job and make sure you are better than anyone else. If you have an incident on your record and someone else doesn't then the choice may be determined on that single aspect.
Many Drivers have an incident on their record somewhere and new Drivers within their first 3yrs are at their highest risk. This is well known industry wide. I've known Drivers who have gone 20+ yrs without incident then suddenly have a couple in a row.
When you change TOC/FOC there will be a request for the incident record to be transferred. It's all part and parcel of switching employer.
Carl98k
5 Apr 2020
Plymouth
Hello,
I did the tests with GTR. I passed to national standard but failed the DFFT. I need to wait 6 months to do any psychometric tests, and I do I’ll only need to pass the DFFT. This came direct from the recruitment cell.
