Network Rail New Measurement Train (HST) out of service until 2020?
Discussion in 'Traction & Rolling Stock' started by jaketaylor, 27 Oct 2019.
  1. jaketaylor
    jaketaylor Member
    28
    4 Oct 2019
    Darlington
    Hi all! Not sure if this post belongs in here! I’ve just been told something about the network rail hst being out of service until January 2020? Is this true? If so what are the reasons?
    Rail Forums
  3. Elecman
    Elecman Established Member
    1,928
    31 Dec 2013
    Lancashire
    Due a maintenance exam?
  4. AnthonyRail
    AnthonyRail Member
    1,076
    11 Jan 2015
    Oh what’s replacing it. 37s.
  5. MELVYN
    MELVYN Member
    17
    14 Jun 2015
    EXETER
    67s They have been in Devon this week.
  6. anthony kelly
    anthony kelly Member
    21
    19 Dec 2018
    DERBY
    Suppose to be a pair of class 67s
  7. Boodiggy
    Boodiggy Member
    233
    8 Nov 2012
    MK
    Correct - it has various planned maintenance and this is one of the bigger exams including all systems calibration etc etc.
  8. Aictos
    Aictos Established Member
    8,990
    28 Apr 2009
    Are the 67s running around at 125mph or a lower speed?
  9. jaketaylor
    jaketaylor Member
    28
    4 Oct 2019
    Darlington
    Ah ok thanks all for the information! I just wasn’t sure as why it was going to be out of service until January! Ive also seen class 37s will be doing some of the test trains as well as 057+219 covered it’s weekly run to heaton
  10. jopsuk
    jopsuk Veteran Member
    12,152
    13 May 2008
    it's a bit weird processing that "until 2020" actually means "for a couple of months".
  11. Class 170101
    Class 170101 Established Member
    5,557
    1 Mar 2014
    I'm surprised that they do the exam now. Thought it would be in the summer when alternative traction wouldn't be covering RHTT traims.
  12. Townsend Hook
    Townsend Hook Member
    440
    3 Aug 2011
    Derby
    The NMT is undergoing a C4 exam plus modification and replacement of some of the recording equipment. It is due to commence test running w/c Monday 16th December, with it resuming operational shifts from Saturday 21st if all goes to plan. NMT shifts are currently being covered primarily by the Colas 67s with certain shifts being covered by Colas 37s as required for scheduling reasons, or due to class 67 route availability. As an aside, one NMT shift has recently run with DRS 37s (059 and 716) on hire to Colas.
    The NMT is being covered by the PLPR1 and PLPR2 loco-hauled test trains, which are limited to 100mph.
  13. Bezza49
    Bezza49 Member
    53
    21 Nov 2018
    Euxton
    Any chance of Network Rail snapping a couple of extra redundant HST's from the growing pool of stored examples? They could make two NMT's and cover the network twice as quick ;)
    (I am aware its not that simple!)
  14. Aictos
    8,990
    28 Apr 2009
    What are PLPR1 and PLPR2?
  15. Nick Ashwell
    Nick Ashwell Member
    156
    20 Dec 2018
  16. Aictos
    8,990
    28 Apr 2009
  17. Townsend Hook
    440
    3 Aug 2011
    Derby
    The PLPR1 and PLPR2 formations are two of the five track recording formations (PLPR1-4 and NMT) used as part of a four-weekly pattern of track recording runs around the country. PLPR (Plain Line Pattern Recognition) is a visual system used to replace manual track patrolling. PLPR1 and 2 each incorporate one of the Mk2 PLPR recording vehicles (PLPR1 72631 and PLPR2 5981), a radio survey vehicle for monitoring the GSM-R network, an overhead line inspection vehicle (although 975091 MENTOR is currently missing from the PLPR1 formation for a couple of months while it's own recording equipment is upgraded), plus a brake runner.
  18. Townsend Hook
    440
    3 Aug 2011
    Derby
    Acquiring more class 43 power cars to work with the Mk1/Mk2-based PLPR sets wouldn't be the stupidest idea in the world. Significantly more modern and powerful than the 37s, and with more route availability than the 67s.
  19. Tempest3K
    Tempest3K Member
    106
    16 Feb 2015
    York
    I suspect the answer to that lies with D(a)fT and if they are willing to loosen the purse strings a little....
  20. 43096
    43096 Established Member
    6,295
    23 Nov 2015
    Ummmmmm. Why?
    If NR can make a business case for it, then they can go ahead with it. I’m not aware that DfT control NR as tightly as the TOCs.
  21. Hairy Bear
    Hairy Bear Member
    185
    13 Feb 2011
    Derbyshire
    Which is why they have been sniffing around our ex Grand Central ones.
  22. Tempest3K
    Tempest3K Member
    106
    16 Feb 2015
    York
    I'd expect something like creation of another NMT to be a special bid for funds rather than coming out of general funding due to its specialist nature - happy to be corrected if someone knows differently :)
  23. Class 170101
    5,557
    1 Mar 2014
    In light of the recent incidents at Margam and elsewhere I'm surprised that working red zone is still allowed (I believe Scotland zone is banned) and that the idea of manned track patrolling seems decidedly old fashioned these days if the same job can be done 'electronically'.
    A good sign maybe but presumably more Mark IIIs (or even Mark IVs) will need to be acquired to increase the amount of coverage done.
  24. GWHST107
    GWHST107 Member
    95
    28 Apr 2019
  25. D365
    D365 Established Member
    6,708
    29 Jun 2012
    Is there a reason for favouring the use of buffered 43s?
  26. duffield
    duffield Member
    940
    31 Jul 2013
    East Midlands
  27. The_Train
    The_Train Established Member
    2,073
    2 Jun 2018
    I've seen a TOPS list at 1400 today and both 43013 and 43014 are showing as at Derby RTC. So either TOPS hasn't been updated or they stopped reporting on RTT yesterday for whatever reason but did make it home
  28. Doomotron
    Doomotron Member
    578
    25 Jun 2018
    Deal
    Are they getting PRM modifications? ;)
  29. Rikki Lamb
    Rikki Lamb Member
    36
    24 Jan 2019
    Simplification of coupling if there is a fault and the train requires rowing I suspect
  30. 43096
    6,295
    23 Nov 2015
    Assuming you mean the current set, I'm not aware that they are favoured. Normally the power cars will stay on the set until they need to be swapped off for maintenance reasons.
  31. D365
    6,708
    29 Jun 2012
    I was referring to the buffered ex-GC power cars that are currently with EMR. The question being why Network Rail would favour them, rather than ex-LNER power cars, if they needed to bolster their stock of yellow Class 43s.
Share This Page
