New lines and improvements for Sussex railways
DynamicSpirit
12 Apr 2012
SE London
It is going to be costly either way, I can appreciate that.
Isn't there already a decent service to Brighton (up to 4tph) on the East Coastway that can be interchanged with at Lewes?
It's not a bad service, although does have 20-minute gaps. But it's an extremely well used commuter route. Checking Wikipedia and doing a couple of sums says that the three intermediate stations (London Road, Moulsecombe and Falmer) between them serve on average over 5000 entries/exits a day. I would argue the line from Brighton to Lewes could and should sustain a turn-up-and-go service, so could support a couple more tph. And ultimately, Brighton is going to be the biggest destination for people coming from Uckfield/etc. and it seems more sensible to provide direct services to the main destination while passengers for the secondary destinations need to change trains, rather than the other way round :)
More trains from London via Gatwick to at least Haywards Heath and potentially Lewes.
You seem to be advocating removing 2tph of existing trains that run from London via Gatwick to at least Haywards Heath and Lewes (ie. the current London - Eastbourne/Hastings trains) in order to provide more trains on the exact same corridor. I'm confused! :D
Bristol
Pre-Covid I'm fairly sure there were 5tph between Lewes and Brighton - 2tph slow from Seaford, 1tph extra between Brighton and Lewes and 2tph fast Brighton-Eastbourne. Brighton-Falmer should certainly have a metro-type service and Lewes is a sensible place to turn that back, although the signalling headways down that line may limit how many slow trains can run.
Zomboid
2 Apr 2025
Oxford
People are far too interested in trying to rebuild yesteryear's network, and don't look at what the changes since the 60s have meant for both demand and how the network operates
I agree completely with this, but if the Lewes to Brighton line ends up being turn up and go frequency with a combination of Seaford, Eastbourne and possibly Lewes origin trains, then would that not give Uckfield passengers adequate access to Brighton? Putting a line in that approaches Lewes from the north would seem a notably simpler proposition than going round to approach from the east.
Bristol
Why is this:
Significantly easier than this:
There is no heritage railway to disrupt, no level crossing faffing about at Hamsey, and you have a far more flexible network in return. Freight can't route via Oxted easily anyway because of the viaduct, all other traffic can reverse in any platform long enough at Lewes to enable Uckfield-Eastbourne or Seaford if so required for any reason. And if you *really* wanted, you could add a loop outside Lewes for freight to drop in and runround if needed.
Only problem is you'll have to do it quick so that housing development doesn't fill the gap.
AlastairFraser
12 Aug 2018
If you join north of Lewes you need a reversal beyond the station to access Brighton. Simplicity is key for todays network. Joining east of Glynde allows for the maximum flexibility with minimal additional infrastructure. No need for reversing turnbacks or extra chords, just 1 junction and then trains have a choice of platforms at Lewes to reverse in if needed, or can head straight on to Brighton.
People are far too interested in trying to rebuild yesteryear's network, and don't look at what the changes since the 60s have meant for both demand and how the network operates.
I'm not convinced that you desperately need a direct link to Brighton, but fair enough.
East Coastway currently only has 2tph + freight from the BML, and they would almost certainly need to remain.
I thought that there was 2tph Brighton to Seaford, 1tph Brighton to Eastbourne, and 1tph Brighton to Ore (and vice versa).
So surely 4tph at Lewes would provide a decent connection?
Fair point, they are really busy. Brighton could do with a few tram lines as well, but that's a discussion for another thread!
To clarify
- extending the existing Uckfield services to Eastbourne/Ore, to replace Victoria to Eastbourne/Ore via Gatwick.
Then doing something with the paths of those former services between Lewes and London via Gatwick.
Could be an additional service the whole way Lewes to Victoria, could be a service to somewhere else like Guildford to create new links etc..
NCT
18 Apr 2025
Three things I've noticed.
1) it's only 4tph in the peaks, so arguably the point about a lot of trains is less of an issue, as East Grinstead has an hourly service off peak - this means that sharing a heritage line could be possible just with breaks in service for those times. If we're talking peak hour capacity, then the loss of Gatwick services are potentially less of an issue.
2) 2tph from East Grinstead are Thameslink services, as such you could deliver from Eastbourne 1tph (existing) and 2tph (Thameslink) and still find a lot of people use the new services because it better connects to other areas in London
3) the journey time between East Croydon and East Grinstead can be 13 minutes shorter by missing out most stations, if you timetable the stopping service far enough ahead of the faster services you could gain a bit of that 30 minutes back
For example 5tph:
xx:00 fast service (Thameslink)
xx:05 fast service (Victoria)
xx:20 stopping service (Victoria)
xx:30 fast service (Thameslink)
xx:40 stopping service (Victoria)
The fast services could extend to Eastbourne, giving it 5tph by retaining 1tph via the existing route.
Yes the second train per hour to Victoria would be longer but at (say) 20 minutes longer it would still get you to London sooner than waiting on the next service so people would still use it. Whilst that would put more pressure on the retained service, some of that would be reduced by being able to get a Thameslink train which would reduce the journey time to get to (say) Blackfriars (or at least make it much more attractive as it's then a direct service - as you could just sit in a seat when you get in and then get off in London rather than squeezing onto a train in Croydon to stand into Blackfriars).
Those 4 trains north of East Grinsted would be well loaded, but empty between East Grinstead and Haywards Heath and half empty towards Lewes.
There aren't enough Class 700s to send to Eastbourne.
Timetabling-wise, anything other than a perfect 30-minute cycle is a recipe for disaster.
Today, Eastbourne and Lewes have a clockface 30-minute service to Victoria and it's a 3-minute cross-platform interchange onto a Thameslink service at Haywards Heath. Nothing proposed by anyone demonstrates an improvement on this timetable, and nobody has demonstrated tangible benefits to other network users to make Eastbourne and Lewes users' sacrifices worthwhile.
A two-track railway south of Balcombe Junction handling a mix of stopping patterns is a challenge but hardly insurmountable. Capacity crunch is Haywards Heath northwards, but that can addressed by being able run Three Bridges starters, Gatwick starters (GatEx back up to 4tph with sensible fares), 4tph from East Grinsted for more hours, and separating the Cats and Tats. Those trains don't all have to start from Brighton. The infrastructure constraint is Croydon Area - once extra paths are released by a fundable version of CARS those paths don't need to take the scenenic route via East Grinsted all the way to Eastbourne.
The best case of a 15-minute journey time penalty (fast north of East Grinsted if you could get the timetable to work) would require Bluebell to be upgraded to 75mph - that means complete rebuild (ballast level) and resignalling. Network Rail would have to regain stewardship of the line and Bluebell would have to to pay access charges and have modern train protection equipment installed on their trains. It's a complete non-starter.
Why are separate trains for Caterham and Tattenham Corner needed, except on one Saturday in June?
The removal of the various mainly empty stopping services on the slow lines south of East Croydon has improved Redhill reliability.
Bristol
Brighton is far and away the biggest draw after London for the Wealden Towns. The Univeristies of Brighton and Sussex (at both Moulscomb and Falmer) are busy with traffic to/from London as well as the Premier League games at Falmer. London Road (Brighton) is a busy urban area but would be a journey generator rather than a particular destination in it's own right.
You don't *desperately* need the link, but if you're building Uckfield-Lewes it makes /vastly/ more sense to orientate it for direct Brighton services than to force an awkward shunt at Lewes. Orientating it this way also makes reversals for Eastbourne/Seaford Services much more smooth as they're in the platform at Lewes.
I was talking about paths via Plumpton.
Indeed.
To clarify
Eastborne/Ore should be prioritised via Gatwick for journey length reasons. Paths between Haywards Heath and Gatwick should be prioritised on the main draw (London) given the demand profile.
NCT
18 Apr 2025
When trains from the quarry lines and Red Hill arrive at ECR relatively full, having 6tph (4tph Thameslink, 2tph Vics probably don't need separating) with a bit of room on them would be very welcome. This would complete the 12tph East Croydon Thameslink service (at 5-minute intervals) and finally deliver 24tph through the core.
This would be after CARS so the increased tph could be accommodated reliably.
CARS does nothing to sort out the infrastructure south of Croydon, which on the slow lines as far as Purley isn't particularly great so putting more trains over the slow lines at South Croydon doesn't seem to be a good idea. In any case, is running more Thameslink services better than improving South London's connectivity to East Croydon?
I think it will be another generation before the CARS plans are dusted down, and even then many years of disruption for it to be enacted.
NCT
18 Apr 2025
Having 4 SL platforms at East Croydon should allow at least 2tph from each of the Selhurst and Norwood Junction slows to terminate from the north.
The SLs between ECR and Selsdon Junction in this would would handle 12tph in the peaks (6 towards Oxted, 6 towards Purley), with the Redhills staying on the fasts until Stoats Nest.
Then any East Grinstead or Uckfield would be two generations away! :lol:
AlastairFraser
12 Aug 2018
Fair point.
I'm not sure the journey time would be much slower at all via Uckfield.
Whichever route you choose Uckfield to Lewes, it shouldn't take more than 10 mins, and there are significant improvements to be made to journey times north of Uckfield with a EMU, compared to 171 acceleration.
Bristol
Fair point.
'much' in this context is relevant, as was dicussed upthread about EG-HH. London to Eastbourne is already around an hour and a half. Adding 10 minutes to that does have quite a significant negative impact. Now 10 minutes extra runtime is better than no train at all, but in my plan Eastbourne continues to receive the fast, long services it already has, 1tph Uckfield is extended to Brighton, and there is the option for a 2nd London path to either serve Brighton or Seaford (splitting is possible but not preferable).
AlastairFraser
12 Aug 2018
Fair enough.
Brighton is probably a better destination than Seaford if you were choosing between the 2
Bristol
Fair enough.
'Probably' is massively underselling it. Seaford and Newhaven would benefit from direct London trains but very much as a journey generator, not a destination. Rail travel to the Ferry is minimal, going by the total number of foot and bike passengers when I've used the Newhaven-Dieppe ferry.
AlastairFraser
12 Aug 2018
I used it a couple of weeks ago and there were significant numbers of passengers transferring to/from rail in both directions, but not in comparison with London numbers I agree.
PGAT
13 Apr 2022
Selhurst
Would it not be possible to run both Brighton and London trains as far as Newhaven Harbour and then one of the services can turnaround at Newhaven Marine?
Bristol
Fundamentally yes, although I suspect the single line to Seaford could probably take the extra path anyway.
It doesn't matter that much either way if the ferry only goes once or twice a day.
two sailings a day in winter and three in summer but yes.
