New OeBB NightJet connections to Brussels
Discussion in 'International Transport' started by tasky, 6 Oct 2019.
  1. tasky
    tasky Member
    304
    30 Oct 2018
    This could have implications for British travellers going to Vienna as well – what routes could it open up?
    https://www.politico.eu/article/nig...9issWJo9cUAf6plU97BtTg_SIQkWebTsZZBJHXeren5zQ
    Rail Forums
  3. Alfonso
    Alfonso Member
    158
    22 Jul 2017
  4. duesselmartin
    duesselmartin Member
    1,121
    18 Jan 2014
    Duisburg, Germany
    I guess the only route would be via Cologne? Would that mean a temporary end for Düsseldorf?
  5. EAD
    EAD Member
    175
    14 Nov 2014
    Also it is still sketchy at the moment, but suggestion on-line is Sunday/Wednesday nights to Brussels and Monday/Thursday nights back to start. Clearly targeting those that need to travel out and back for meetings at the various institutions in Brussels e.g. on a most of the week basis.
  6. 87015
    87015 Established Member
    4,355
    3 Mar 2006
    GEML/WCML/SR
    Possibly a portion, they use Dusseldorf for the cars so would presumably retain it. OBB Taurus can't reach Belgium so will need a change of loco anyway so a portion doesn't make it that complicated.
  7. EAD
    EAD Member
    175
    14 Nov 2014
    That would make sense, though currently the rolling stock rotation on Vienna/Innsbruck is on a triangular basis to ensure stock gets back to Vienna for servicing so it needs to fit into that. Also share need for the ARZ service to be retained no matter for Düsseldorf, otherwise you sabotage your existing base.
  8. tasky
    tasky Member
    304
    30 Oct 2018
    Yes this is true, though I think probably all journeys would become significantly cheaper as it removes the need for an ICE/Thalys ticket. If the pricing model is the same as as other OeBB routes it will be no cheaper to go from Brussels to Vienna than Cologne
  9. tasky
    tasky Member
    304
    30 Oct 2018
    Though actually, thinking of a journey from London, I suppose people might be using the London Spezial ticket which is often as cheap as the Eurostar anyway
    Good news for Brussels though
  10. Alfonso
    Alfonso Member
    158
    22 Jul 2017
    Agree it's all speculation, but a split or alternate days service sound reasonable options, with the Dusseldorf portion/nights having their start extended/reinstated back to Amsterdam later.
  11. Bletchleyite
    Bletchleyite Veteran Member
    46,742
    Up and down the south WCML (mostly)
    As I said on Twitter - they need to reinstate, depending on route, either the "Orient-Expreß" (I think strictly the Direct-Orient-Expreß) or "Donauwalzer" names. Only a temporary absence for those two great historic trains.
  12. JonathanP
    JonathanP Member
    184
    1 Aug 2008
    Berlin, Germany
    Not really the same thing, but in the new timetable "Donauwalzer" will be used for Hamburg - Wien train pair.
  13. duesselmartin
    1,121
    18 Jan 2014
    Duisburg, Germany
    Donau Kurier was used ob the Ruhr to Wien services in the past.
  14. Bletchleyite
    46,742
    That's the wrong historic name:
    https://de.wikipedia.org/wiki/Ostende-Wien-Express
    confirms, as I thought, that the Donauwalzer was classically the train pair EN 224/225, previously Oostende-Wien-Express. I can't remember what Hamburg-Wien was, but it wasn't that. Good to see a classic name back, though, even if for the wrong train!
    The Donau-Kurier was the separate train (later one of the CNLs) to the Ruhr but not beyond.
Share This Page
