The first 25 Wascosa JNA virtual-quarry ballast wagons are now at Eastleigh East Yard looking very smart* in all-yellow livery. I presume they'll soon be heading empty to Mountsorell and/or Cliffe Hill, though the existing wagons in those flows do look quite serviceable. Another 25 JNAs are to follow, then 260 Falcon possession ballast box-wagons to augment and eventually replace the fleet of ancient MHA/MPA 2-axle wagons, many with 50-year-old ex-HAA frames. (*not yet defaced by unsightly graffiti!)
After that we can expect 260 flat wagons with various modules for conveying spoil, ballast, sleepers and recovered track. This should finally see the demise of the 60-year-old Salmons and perhaps the MXAs based on 1950s BDO frames.
There's a YouTube video of the JNA boxes passing Basingstoke on a 6Z93 from Dollands Moor to Eastleigh on 11 November: (Channel: Dan Warman | Video: GBRF 66751 + Brand New Network Rail 'Wascosa' wagons)
I imagine the current IOA fleet of high-sided bulk ballast wagons will be unaffected, but there have been one or two bulk ballast flows utilising MRA sidetippers (such as ballast from Mountsorrel, and also Redcar) which would be more suited to the new wagons.
There are over 800 MFA/MHA/MPA coalfish wagons still in the Network Rail fleet, not all of them serviceable but still a vast number. A coalfish is more or less half the length, and less than half the carrying capacity of a falcon wagon, so possibly 260 falcons are considered enough to replace the lot of them. The coalfish must be overdue for replacement by now, they were converted over 20 years ago, never mind their previous existence as coal hoppers! I'd be surprised if the MXAs disappeared, considering the boxes fitted to them are fairly new and the bogies are no older than those on a lot of other BR-built steel wagons still in use.
Like RT3973EXL says, I doubt the modules on the new flat wagons will carry ballast or spoil - the
GBRF article about these new wagons says they are "for the carriage of track panels, sleepers, switches, rails and loose materials". By loose materials I suspect they just mean the sort of general "engineers materials" that are put into drop-sided bass or super tench wagons, such as rolls of geotextiles, the timber "dunnage" used between layers of concrete sleepers, small S&C components and so on, rather than ballast or spoil. There are something like 300 salmon wagons in the fleet, if you include the ones converted to "Ospreys" for loading with redundant track panels, so I think most of the 260 new flat wagons will be needed to replace those.
my understanding is that, whilst the bodies can be swapped, this is only to convert the wagon for another use and is not intended to occur when loaded.
I would agree with that, I expect the modules fitted will be semi-permanent fixtures on the wagon that are not removed in normal use.
A standard container of spoil or ballast would almost certainly be too heavy for a standard intermodal wagon.
This comment brought back vague memories of FEA wagons being fitted with modules to carry ballast. Took me a while to track down any photos!
This shows a close-up of FEA wagon 640145 fitted with a pair of low-sided 30ft ballast boxes. The maximum gross weight of each box appears to be just over 30 tons, which would make it equivalent to a pair of coalfish in terms of capacity:
https://paulbartlett.zenfolio.com/freightlinerconflat/h643e7db5#h643e7db5
This is an interesting photo of these wagons in use on a bulk ballast flow from Mountsorrel to Crewe:
https://www.flickr.com/photos/47841/20028824876
I think some GBRF FEA wagons might have had the same kind of ballast boxes, but I didn't find any photos.
In terms of aggregate in (almost) full-height boxes, there is the Hardendale - Port Talbot lime flow, with each wagon carrying a pair of 30ft containers weighing around 30 tons each (there's also the flow of ash from Drax to Appleford in 30ft tanktainers of similar weight). Normal shipping containers can be heavier than this in terms of weight vs length- a 20ft container can weigh 30 tons, if it has a very dense payload, meaning it is impossible to carry three fully laden 20ft boxes on a 60ft bogie flat.
Freightliner have used flat modules & boxes on intermodal wagons for infrastructure traffic. Also STVA flat modules for autos traffic.
GBRf used flat modules and box modules for NR traffic and their LUL infrastructure contract.
DBC used modules on the FDA wagon as well as fitting new bodies to old wagons.
The FEA wagon has seen a number of different modules attached for various uses. Match wagons for Kirow Cranes, sleepers carries for Balfour Beatty NTC etc.
This should end the use of 2 axle wagon on infrastructure work and maybe the older bogie wagons. I'm not that up to date these days.
Makes me wonder if the 2-axle "bass" wagons will survive for general materials, or be replaced by "super tench" modules on the new flat wagons.
I was looking up photos of some of the current and former infrastructure modules used on flat wagons:
FEA with "super tench" modules:
https://www.flickr.com/photos/brianews/5853989023/
FEA in use for carrying concrete sleepers:
https://www.flickr.com/photos/153712773@N08/33373536008/
Apart from the Balfour Beatty wagons used with the New Track Construction machine, I don't think any FEAs are currently used on infrastructure traffic - probably due to the upsurge in container movements.
The LTSV website has this profile on FEA wagons which includes information on their former uses on infrastructure services:
https://www.ltsv.com/w_profile_051.php
Some FCAs have been fitted with "super tench" units, probably to replace the FEAs -
https://www.flickr.com/photos/153712773@N08/50659977823/
YQA (former "Parr" sleeper carrier) converted to "super tench."
https://www.flickr.com/photos/davekirwinphotography/49859430307/
Apart from 5 super tench conversions I think all the "Parr" sleeper wagons have gone. The fairly similar "mullet" wagons (for rail) are almost extinct too.
There is one FJA "super tench" surviving (I think these were older freightliner flats). A nice photo of one of these loaded with "Teram" geotextiles and rails:
https://www.flickr.com/photos/dwbphotos/15557860775
The FJAs were in the same number series as the now withdrawn FDA wagons, such as this one loaded with concrete sleepers:
https://www.flickr.com/photos/trevor-plackett/21057167233/
I've noticed some of the wagons carrying concrete sleepers from Doncaster are actually KFA container flats fitted with a flatbed "salmon" module - shown clearly here:
https://www.flickr.com/photos/tayrail/49476519583/
Despite these 260 new flat wagons with their modules being described as a "ground-breaking solution," it does appear to be a continuation of a common practice of adapting container flats for infrastructure use.
