Most definitely. It looks to be a very good model and at those prices you can't say that's a bad deal. Just hoping now that other manufacturers might follow suit!
That is a good price actually. It looks like a lovely model.
Again - thanks very much. Let's hope those Dapol units get here!Ever Given is off Sardinia now, not actually rushing along!! 11km/hr
I expect Dapol aren't going to be too happy with this news! Whether the UK-bound items arrive here in August depends on how long it takes to find another ship with enough space on, I suppose. I'd guess that maybe Dapol's products will get here at the tail-end of August or maybe within the first few days of September.Ever Given is passing Ibiza now. Apparently it failed its seaworthiness inspection and has been limited to 10 knots. It will sail to Rotterdam and be fully unloaded.
The consequences of this are: -
1 - At that speed it will not make Rotterdam on 25th July at 18:00 as predicted. It has c 2000 miles to do at 10 mph, that's 200 hours or 9 days, so July 30-31.
2 - Instead of the ship unloading them coming to the UK, it will be unloaded, stored and then reloaded onto another ship to queue to enter the UK.
So, will they arrive in August at all?
The ETA on the marine traffic has the 29/07/21 02:01.Ever Given is passing Ibiza now. Apparently it failed its seaworthiness inspection and has been limited to 10 knots. It will sail to Rotterdam and be fully unloaded.
It has speeded up to 12 knots
We have been assured we will now receive them by the end of this month, so reveal should be in early - mid August. Once we get them we will post them on here.
Built by General Motors Electro Motive Division between 1985 and 1995, these powerful diesel electric locomotives were designed to haul heavy freight services as a replacement for the class 56 locomotives. 15 of these locomotoives were produced between 1985 and 1995 with the first one being delivered into Southampton docks in 1986. These locomotives have been painted in various different liveries including DB Cargo, GB Railfreight, Foster Yeoman, Mendip Rail and Amey Roadstone Construction.
GM2210501 Class 59 003 'Yeoman Highlander' GBRf
FEATURES
- DCC Fitted
- Detailed body with etched grills and separately fitted hand rails
- Etched nameplate if appropriate
- Darkened wheels and pin point bearings
- All wheel drive
- All Wheel pick up
- Directional lighting
- NEM couplings
- 5 Pole motor for smoother operation
- Includes both standard and knuckle couplings
- Includes spares bag with additional detailing parts
Peco have shown updated decorated samples for their range of Lynton & Barnstaple brake van! Pre-order yours: https://t.co/GF7rG0ymcM pic.twitter.com/6NIHqfKAyu
DCC Capability: Not applicable
Detailing
Bodyshell - factory-fitted separate details
- Bodyside Steps
- Chimney
- Door handles
- Handrails
- Chassis/underframe detail : Framework
- Cab, footplate & interior detail : Detailed
Bufferbeam detail (pre-fitted)
- Pipework - pre-fitted to front
- Pipework - pre-fitted to rear
Mechanical
- Working cosmetic features : Working sliding doors
- Coupling socket/mounting : Non-NEM socket
- Weighting (to assist adhesion) : Within chassis
- Body Construction : Plastic
- Chassis construction : Plastic & metal
- Minimum radius : Radius 2
- Coupling type : Narrow gauge hook & loop
An exclusive look at Rails LNWR Precedent, Caledonian 812 class and Gast Turbine plus Accurascale Deltic with Lawrence Robins of the MRC and Howard Smith.
Price: £36.95Rails is leading the way and innovating for model enthusiasts. These models have been researched, designed and produced solely in the UK.
Manufactured using new cutting-edge technologies featuring:
Rails aim to fill the need for niche products, which simply would not justify a large production run. As they are produced in limited quantities, these vans are priced slightly higher than mass produced items, however, we feel the price reflects fantastic value for such distinctive models.
- A new, ultra high resolution, super strong aeronautical grade PU with a design life exceeding 25 years.
- A build process using the very latest light technology and is infinitely flexible for making all variants.
- Low volume production potential for niche, products previously not capable of being produced economically for RTR.
A tremendous amount of research and development has been put into this project to ensure accuracy and true replication has been achieved.
Probably in the same shipment as the 92's, the decorated samples for Accurascale's Mk5's are not far away either.This morning, on Model Railway News...
- Accurascale Class 92s in OO gauge - decorated samples expected by the end of July and reveal expected early-to-mid-August
As usual, details given in spoilers below.
@Accurascale Fran when should we be getting news about the MK5's for the decorated simples?
We're hoping within the next 10 days. Once we have it we will share it here.
Ah cool - thanks for sharing. It's good that they should be arriving around the same time.Probably in the same shipment as the 92's, the decorated samples for Accurascale's Mk5's are not far away either.
Mark 5, By Accurascale - Page 28 - Accurascale / Irish Railway Models - RMweb
Project Update - 26th July2021
We have received the first engineering prototypes of the GWR Steam Railmotor and these are being fully evaulated and tested.
The models have electrical pickups on all wheels, they have full working valve gear including the radius rod and piston valve stem. The 1020 coerless motor is positioned vertically completely hidden inside the actual boiler of the power bogie. They have working directional oil lamps and interior lights. The models will be DCC ready with a 21-pin decoder socket and 28mm speaker preinstalled.
We have already identified a smalll number of minor issues to amend, initial runninng tests show that they run very quietly and smoothly and the valve gear is a joy to watch in action
The livery artwork is underway concurrent with testing these EPs and we hope to see decorated samples by the autumn, we should then be in a position to start to arrange production.
The tooling allows for both the Diagram ‘O’ type and the Diagram ‘R’ type Steam Railmotors to be produced in five versions, as listed below. The diagram O type most obvious differences from the diagram ‘R’ are the larger boiler room windows, double leaf passenger doors and ‘Fishbelly’ rather than ‘Equalising’ bogies.
Click here for details of the versions available
And finally for this update a brief video to show the valve gear in action
The Models
We are producing five versions, as detailed below click on the item to pre-order:-
K2301 GWR Steam Railmotor Dia. R Number 93 (As preserved) £179.99 (£169.99 for pre-orders)
K2302 GWR Steam Railmotor Dia. R Number 97 (Simplified GWR Chocolate & Cream late 1920s onwards) £179.99 (£169.99 for pre-orders)
K2303 GWR Steam Railmotor Dia. O Number 63 (GWR Lined Brown 1908 - 1912) £179.99 (£169.99 for pre-orders)
K2304 GWR Steam Railmotor Dia. R Number 85 (GWR Lined Crimson Lake 1912 - 1922) £179.99 (£169.99 for pre-orders)
K2305 GWR Steam Railmotor Dia. O Number 61 (GWR Fully Lined Chocolate & Cream 1903 - 1908) £179.99 (£169.99 for pre-orders)
Ah cool - thanks for sharing. Those models are getting closer and closer!Dapol/Ever Given update - now off Cherbourg and for the last few hours been doing around 1 to 2 knots.
It'll get dizzy before too long!
Possibly waiting until its arrival at Rotterdam? Another vessel nearby had a eta of tomorrow while the Ever Given has a eta of the 29th.It'll get dizzy before too long!
In all seriousness, though, what on earth is up with that?
-Peter
Ah yes, should've worked that one outPossibly waiting until its arrival at Rotterdam? Another vessel nearby had a eta of tomorrow while the Ever Given has a eta of the 29th.
I hadn't realised it had got so close to Rotterdam!
-Peter
I didn't realize at first as well! Think it is easier to wait in a wider area of the channel and not in the busy Dover/North sea area.Ah yes, should've worked that one out
-Peter
Super - thanks again for the updateI didn't realize at first as well! Think it is easier to wait in a wider area of the channel and not in the busy Dover/North sea area.
The Ever Given is on the move again and will pass Calais shortly.
Again - thanks for the update. I'll keep an eye out for that.Accuascale have posted on the mk5 thread that a update will be posted late in the week.
Now I'm on my PC here is the post on the RM web for the Mk5's showing two of the sleeper vehicles.Super - thanks again for the update
At least it's getting here!
-Peter
Now those look amazing. If I didn't know they were models, I'd have said that was a real photo!Now I'm on my PC here is the post on the RM web for the Mk5's showing two of the sleeper vehicles.
Has a ship for Felixstowe been confirmed/found? My understanding (as of a few days ago) was that the cargo would be unloaded from the Ever Given at Rotterdam and then they would just wait for an available ship which was heading for Felixstowe to put the containers on.Ever Given has docked in Rotterdam
What is the name of the transfer ship to Felixstowe?
(Source: https://www.rmweb.co.uk/community/i...s-ever-given-released-from-suez-canal/page/2/)Depends how many boxes need to come off, how many need to go on, and how many need to go back on, but a turnround in 48 hours shouldn't be too difficult in a well equipped container port with several cranes working simultaneously, But on the other hand i have seen large box ships in port unloading/loading for 4 days or so. but she has cargo to transfer to another vessel so might take a lot longer,
Current ETA for Felixstowe is 08 August according to EverGreen
(Source: as above)Unloading will take longer as the containers that were due for discharge at Hamburg are coming off at Rotterdam, and will be transhipped. The vessel was due to sail the following day after Rotterdam arrival, for Felixstowe, but not sure if that will still happen, it's not on the Felixstowe expected list.
I wonder if it will be taking on any containers at Rotterdam and Felixstowe, as it probably has to go for further examination and possible repairs.
the Ever Given will remain in Rotterdam until Monday, when she's expected to sail for Felixstowe in Britain, before going to into a dry dock in Dunkirk in France for a further inspection.
July 30, 2021Fran Burke
Sweet Dreams Are Made of These - Decorated Mark 5s!
It's been just over six months since we previewed the first tooling samples of our long awaited and highly anticipated Mark 5 coaching stock. A lot of work has gone on behind the scenes to develop our first coach project in that time and today we can bring you a full update on where we're at, the challenges we're currently working on, show you some lovely decorated samples and outline where we go next.
So, first things first; let's have a look at these beautiful sleeper samples!
We always use high resolution, pin sharp images to show off our models (unlike many other manufacturers!), warts and all, so you can get a full close up view of the models. With this in mind, please remember that these are pre-production coaches and fit and finish will be improved further on the production models which will roll around on your layout.
Having said that though, the sleeper coaches are looking mighty fine and promising! We do see some improvements and tweaks that must be made, but we are sure you will agree the deceptively complex livery is coming together nicely with a lovely colour match for the tricky Caledonian Sleeper midnight teal.
As you can see from the above shot, the detail on these coaches is delicious, with a wealth of boxes, grilles, cylinders and conduits replicated as per the prototypes.
Another area we are particularly proud of is our magnetic Dellner couplings, which make for some serious close coupling up to 3rd radius curves! We plan to sell these separately too, as they just plug into NEM sockets. More on that at a later date. Of course, each coach pack will also come with a set of tension locks for each coach to help negotiate 2nd radius and couple to other items of stock.
Naturally, being Accurascale models, our Mark 5s are top of the line when it comes to specifications, such as a wealth of separately applied parts, attention to detail, lots of printing and of course, lighting, which as you can see above, is nice and subtle and devoid of dreaded light bleed.
Improvements? Well glazing of course, some printing such as the warning labels and smaller signs will be very much improved on, the overspray in areas will simply not do and will be corrected on the finished models. Overall though, they're looking well on course and very tasty indeed.
So, that's the sleepers, what about the TPE sets? Well, there's a whole other story!
If our factory thought the Caledonian Sleeper livery was complex with it's wealth of warning labels, then the TPE sets have well and truly broken their hearts! With a similar amount of warning labels, interesting angles, shades and fades, it really pushes model production techniques to the very limit.
We have so far tried a couple of techniques to replicate this livery faithfully, but so far it has ended in failure, and has taken many months of trial and error to attempt to get this livery right. As we add all the layers to the livery, it begins to damage the paint finish elsewhere as you can see below on these test bodies. It has proven very frustrating for our factory! The visible paint lines through the doors were also unacceptable.
Our factory does not give up easily however, and is currently working on a new batch blending various techniques to get the desired finish to set these models apart and we have every confidence they will achieve it. Unfortunately it means we will not be able to bring you pictures of fully finished TPE sets just yet, but as you can see above; they're edging closer and closer and they will look awesome when complete.
So, where does that leave us? Well, the Sleepers have been assessed and our feedback is on its way to the factory. The factory has assured us that we will have finished TPE samples for assessment in 8 weeks time. Unfortunately until we sign off on those TPE coaches we will not have a production delivery date, but can confirm it will be in 2022. We are very sorry for this delay and certainly had hoped we would be further on in this project, but we of course did not foresee this livery challenge!
Keep an eye on our website news section, email newsletter, Facebook and Twitter feeds, RMWeb section and of course the news pages for an update on the TPE livery samples in 8 weeks time and with it a firm delivery date as they enter production. In the meantime, secure your packs with a £30 deposit, via our website by clicking here.
I've not yet watched that video but saw a screenshot earlier on Twitter and they look good. But it does sound odd if Heljan are already making one!Bachmann doing a brand new 47. Seems a bit odd when Heljan are releasing a new version soon.
