On Aug 6, 11:27 am, Mizter T <
[email protected]> wrote:
> On Aug 6, 9:59 am, Bruce <
> > On Fri, 6 Aug 2010 09:45:15 +0100, Ian Jelf
> >In message <
[email protected]>, Bruce
[email protected]> writes
> > >>On Thu, 5 Aug 2010 21:55:02 +0100, Ian Jelf
> > >>>Thanks for posting this. I *really* enjoyed watching it. As a late
> > >>>teenager, T&W seemed the only place in Britain that aspired to the sort
> > >>>of investment and integrated transport I'd seen in Germany. I imagined
> > >>>that it would be the template for other areas but of course things
> > >>>didn't quite work out that way.......
> > >>Liverpool had significant investment in the Merseyrail underground
> > >>system in the 1970s with the Loop and Link lines.
> > >Indeed. But - as far as I could tell - it never truly embraced the
> > >feeder bus ethos of T&W.
> > That's true, but the trains and buses were under the same control, and
> > integrated in the sense that many bus routes called at Merseyrail
> > stations - and had done since pre-Merseyrail days.
> > Was T&W's feeder bus thing widespread? Did it extend much beyond the
> > highly publicised bus/Metro interchange at Heworth?
> Four Lane Ends, Gateshead, Regent Centre were other big bus hubs... in
> fact look at the Metro map and even now it indicates certain stations
> as being 'main bus interchanges':
http://www.nexus.org.uk/sites/nexus.org.uk/files/images/metro/Metro_M...
> I think the whole T&W bus network was more or less reconfigured/
> redesigned in order to serve/ feed the Metro
I think the bit people perhaps don't realise is that while the
interchanges were key in reducing the volume of long distance buses
into Newcastle the entire system was designed to allow integrated
travel. You could travel on one ticket via bus, metro and bus. You
could also use the Ferry as a link with bus connections at both ferry
landings. Similarly you could use the BR line to Sunderland and then
connect onto local buses in Sunderland. It was also possible to
interchange between bus routes *anywhere* with a Transfare ticket thus
paying once for the total number of zones traversed. This latter
ability died with deregulation because bus operators wanted as much of
the market to themselves as possible. When the bus network was
redesigned the timetables were created in a way that provided even
headways between services over common sections to deliberately get rid
of bunching and to give high frequencies. This is another aspect of
the system that has largely gone these days although Go Ahead are a
bit more attentive to even headways than Arriva and Stagecoach. To be
strictly fair there were anomolies as the Carlisle rail line was
outside the "transfare" scheme as were some of the "out county" long
distance buses from County Durham and Northumberland. It was not a
perfect system but it worked pretty well - as a teenager I travelled
extensively around Tyne and Wear with no real worry about journeys
because you'd always get back to a bus service that connected with
others or with the Metro.
Transfares and bus routes serving interchanges still exist but the
valid interchanges are far, far reduced compared to pre 1986. I am
not aware of anywhere else in the UK that achieved the same level of
multi modal interchange and single fare through ticketing that T&W
achieved. It's common practice elsewhere in the world but we're mad
enough to have smashed into little pieces the one example we had in
the UK.
Looking at Paul Scott's [1] comment about Regent Centre - he is, of
course, correct that for Newcastle bound journeys (on the 44, 45 and
46!) then there was little time difference. Nonetheless you could
still look up a bus timetable and see the times of the metro train's
arrival at the interchange and plan your trip. If you started at
somewhere else on the Metro system you could make a confident
connection by linking into the train shown as connecting at the
interchange point. This ability to connect with confidence was
crucial to the system's success.
[1] a fellow North Easterner I see!
Paul C
via Google
