Night lights in the day?
McMetro
18 Apr 2020
Bristol
Recently saw a GWR Class 158(957) pass Up at Pilning with its lights in the night configuration at what was midday on a very bright day! Is there any reason for this?
Class 170101
1 Mar 2014
(Is there such a setting?)
Driver probably forgot or perhaps its Night Lights or no headlights and train failed.
Right Away
18 May 2016
Possibly the day headlight wasn't working properly or the 'mimic' headlight indicator on the driving desk wasn't working properly on the day headlight setting. As long as there is a working headlight (such as the night headlight) available it is not a major issue, just an entry in the repair book for repair the next time the unit goes on depot.
Surreytraveller
21 Oct 2009
Yes, there is such a setting. A Day Headlight is far brighter than a Night Headlight, and wouldn't be suitable for use at night
LowLevel
26 Oct 2013
They're the same brightness on a 158. The night head light is on the driver's side and the day one is on the other side. Using the night headlight reduces glare for other drivers on passing trains and better picks up retroreflective lineside signage which is usually on the left.
If one fails you can use the other without restriction though.
Domh245
6 Apr 2013
nowhere
Also worth noting that on modern (700s onwards) units with the new style of lighting with both headlights illuminated all times, night time lights are dimmer than day (to try and avoid dazzling)
ComUtoR
13 Dec 2013
The 700 lights are referred to as Full and Dipped beam. In all honesty most of the Drivers I know believe the 'Full beam' is the equivilant of the old 'night' setting. The units I drive had the nights as brighter but because they switched sides they didn't dazzle as much. On the 700s you generally just run around on dipped all the time. I did use Full beam but only at the darkest points on the routes.
In my experience it hasn't really been the night settings that are the main issue. I've found that the units with the cyclops eye are the ones that dazzle more. I think its a lot to do with the higher spec bulbs. The older units I've driven... I still have nightmares driving 319s in the dark !
LowLevel
26 Oct 2013
It has been quite entertaining as the guard seeing my front end colleagues' reaction to having to drive class 170s in the darkness with the awful candles fitted to them, after a career of driving 15x with upgraded headlights :lol:
43066
24 Nov 2019
Just remind them the headlights are there in order to be seen, not to see by. If they’re relying on seeing where they’re going their route knowledge isn’t up to snuff :).
507 001
3 Dec 2008
Huyton
Doesn’t work. 802s are horrendous. I’m sure I received laser eye surgery from one coming down Miles Platting a few weeks ago.
