Nikon Lens
traction22
2 May 2016
Tarn
I appreciate this is a vague question, but can anyone recommend (or advise what you use) as a good auto focus lens for bus photography? I've been using the kit lens (18-200mm currently) but think I could do better.
TIA
8A Rail
6 Dec 2012
Why not use a shorter 'zoom' lens instead, such as Nikon AF-S 24mm to 70mm ED f2.8 or may be 18mm to 105mm ED f3.5/f5.6 for your camera assuming it is a DX type (ie D3xxx / D5xxx / D7xxx). An alternative, a fixed focal (prime) lens such as 50mm AF-S f1.8. My experience from taking some bus images, that a focal range of 40 to 50mm is more than sufficient.
traction22
2 May 2016
Tarn
You might have a good point with the shorter zoom, thanks. I am wanting something for better lighting in winter, so a lower f number would be better. I'll start looking :)
I have a 50mm f1.8 but it's a bit restrictive for buses.
8A Rail
6 Dec 2012
Why? It is treated as a standard lens which means it roughly mirrors the area view from your eyes (although a 35mm on DX type is more standard lens). Anything less than that i.e. 18mm / 24mm / 28mm starts to distort vertical / horizontal lines which means you are standing too close to the subject which as I've said distorts the subject. May be you really need to stand back a little bit more and tell the 'wide angle mobile phone' picture takers to do the same too! :lol:
traction22
2 May 2016
Tarn
I'm just used to 18-200mm I suppose. With a none fixed, it's easier to set the shot, especially with moving buses (yes, I agree I may need to move).
Islineclear3_1
24 Apr 2014
PTSO or platform depending on the weather
TIA
Could you elaborate on this please? Do you want to step up to a better lens? I don't use Nikon but think they used to do a 70-300mm zoom lens.
You won't get a "fast" zoom lens at a budget price (i.e. max aperture of f1.8 or above) but a 50mm prime will give you an equivalent of about 75mm on a DX camera. Primes make you move about more ...
traction22
2 May 2016
Tarn
I am not quite sure. I think what I am saying is some of my images aren't as sharp as they could be - I appreciate this is probably a me issue, but was just looking for upgrades which may help.
87electric
27 Jan 2010
Any camera will only do what you tell it to do. That is the reality I’m afraid.
Your 50mm 1.8 should be giving you good results.
Peter Mugridge
8 Apr 2010
Epsom
That sounds more like a focus issue - assuming the lens hasn't had any knocks, are you able to adjust the areas from which the autofocus reads the image? Should be some square like patterns when you pre-press the shutter button; it'll be reading from whichever point shows up when you do that and focussing accordingly.
Can you post up some of the affected images so we can see exactly what is happening with them?
Islineclear3_1
24 Apr 2014
So maybe you need to work on your technique...?
Sharpness is very subjective and depends on many factors. Are you using the correct shutter speed if for example, the bus is moving? Is the bus blurry? Which "bit" of the bus are you focusing on? Can you hear the lens focusing as you press the shutter to take the picture? Can you use back-button focus?
As @Peter Mugridge suggests above; best to post up some examples so we can help
traction22
2 May 2016
Tarn
Thanks all -
To clarify, the 50mm 1.8 is a really good lens but generally not for buses, the lack of zoom is it's main downfall. I could crop, but I don't like to do that.
Since posting this thread I've come to two conclusions, the day time bus shots (see signature for a sample) are OK, it's my group (people) shots which seem not to be as sharp as they could be. That might be an me issue, I fully accept that. I do think though, a zoom with lower than f.3.5 (or whatever my camera uses) would be a good idea generally. Thanks all.
Peter Mugridge
8 Apr 2010
Epsom
I'd agree those daytime shots look perfectly good to me ( and I see you have a nice few from a heritage day in my neck of the woods... :) ).
It would still be helpful if you could post a few of the ones you're not happy with - if we can see them, we might be able to tell you what is happening with them.
Islineclear3_1
24 Apr 2014
The problem with people is that - they move....slight sway etc - including the photographer/camera
You may need to stop down to increase depth of field (smaller f number) as most kit lenses are rubbish wide open (large aperture). Especially if you want everyone in the group to be in focus. And remember, increased depth of field may require a slow(er) shutter speed - hence you need to keep still to avoid camera shake
