Northern bizarre excuse
peters
28 Jul 2020
Cheshire
"Due to a late running freight train at Delamere the line is blocked.
Disruption is expected until 10:45 18/10"
Does anyone know what's really happened? Real Time Trains shows a Chester-Manchester train was terminated at Delamere at 09:20 and is due to restart at Northwich at 10:20, after arriving empty from Greenbank at 10:19!
Efini92
14 Dec 2016
Railhead treatment train probably got stuck
Edit : It looks like a possession overran.
peters
28 Jul 2020
Cheshire
Now it looks like the train for the 10:20 Northwich-Manchester is coming off the Manchester-Chester service, which has been terminated short at Greenbank, while the train which only got as far as Delamere will run to Greenbank and then back to Chester.
peters
28 Jul 2020
Cheshire
Looks like the 10:56 Chester to Manchester is in theory being replaced by 3 buses - 12:00 Chester-Stockport (set down only after Cuddington), 12:00 Greenbank-Stockport (set down only after Plumley) and 11:40 Knutsford-Stockport.
There are still referring to it as a late running freight train! Typically it's happened on a Sunday when there's no services between Chester and Manchester via Warrington.
PHILIPE
14 Nov 2011
Caerphilly
The reasons quoted represent the root cause of the delay.
185143
3 Mar 2013
How exactly was this an excuse?
Exactly. Is Northern's reputation that bad that any reason given that isn't their fault is deemed as an excuse? Sadly I suspect it probably is, certainly outside of enthusiast circles.
Jona26
2 Jan 2013
West Sussex
If it was over-running engineering works that caused a works train to be late leaving the possession site why shouldn't Northern state that?
PHILIPE
14 Nov 2011
Caerphilly
As I said, it is the root cause that shows and this is decided by what code is input to attribute the cause of delay rather than open text. I've seen delays attributed to events that have happened the previous day.
GB
16 Nov 2008
Somewhere
The freight train didn’t have the correct paper work and was stuck and thus delayed. Just because you don’t fully understand the reasons given doesn’t mean that reason is wrong or bizarre.
Mcr Warrior
8 Jan 2009
Do details for the "stuck" non passenger train working appear anywhere on Real Train Times ?
robbeech
11 Nov 2015
Yes, absolutely it is. their reputation is beyond appalling and justifiably so. One would be folly to believe a word they said in any situation as they're well known for being inaccurate. HOWEVER, that doesn't mean that everything they say is incorrect, and quite often they're just following a procedure, particularly when it's the social media staff that are publishing information.
Bob figgis
11 Apr 2020
Tinsley TMD
6C91 Hartford C.L Jn to Crewe Basford Hall S.S.M operated by Colas left the overnight engineering posession at 10:52 am just 152 minutes late from its scheduled departure of 08:20. I presume it is this working that caused these issues today as I cannot find any other “freight” train in that area that was running late enough to impact today’s passenger service.
Bow Fell
12 Feb 2020
There’s no reason in Tyrell for “a late running engineering train” so they’ve gone with the best alternative. They could have used “engineering works not being finished on time”
Mcr Warrior
8 Jan 2009
Presumably this is the one...
Still confused as to whether it was a problem with this freight working or delayed engineering work completion that caused this morning's issue on the Altrincham and Chester line.
P.S. What would the freight have been hauling to/from Hartford / Crewe?
221129
21 Mar 2011
Sunny Scotland
As already stated, it was a paperwork issue with the train.
Because that wasn't the cause and would be a lie.
Which would be correct....
Mcr Warrior
8 Jan 2009
Thanks for clarifying. First planned movement of the day on that section of the line presumably (and blocking everything until authorisation to move could be sorted?)
peters
28 Jul 2020
Cheshire
The terminology used on a social media account or passenger information site should be written in jargon that's easy for the average passenger to understand. If Deutsche Bahn give passenger information at a station in Berlin in Italian, whose fault is it if the information isn't understood?
Mag_seven
1 Sep 2014
here to eternity
At the end of the day 99% of travellers just want to know when their train will turn up and if it isn't going to turn up what the alternatives are. That in my opinion is the information the Twitter teams should be giving out perhaps with a brief explanation as to why there are delays to assist with any future delay/ repay claims.
They should certainly not be wasting their time arguing with enthusiasts about the finer details of delay attribution.
Darandio
24 Feb 2007
The average passenger doesn't understand a reason such as the line is blocked due to a late running freight train? o_O
