Over on London Reconnections I've been discussing an idea I had for implementing a metro service along the GWML. Obviously it's a bit blue-sky, but I thought I'd get some thoughts from posters over here about it.
Basically, the premise is this: When Crossrail opens, the short platforms (13/14 - etc) at Paddington used for metro-like services won't be needed any more as the service will either be run onto Crossrail or cut back (i.e. Greenford to West Ealing). Also, when the OOC redevelopments go ahead, there's a distinct chance the Crossrail depot will be moved away from OOC to permit more redevelopment. The former permits the restoration of 4 H&C platforms, the latter frees up the depot lines from Royal Oak to OOC to use as a segregated 6-track alignment.
This would enable the H&C to gain a branch to OOC very, very easily, and would permit platforms at all of the locations along the GWML clamouring for them that can't be justified on Crossrail (so Royal Oak, Westbourne Park, Ladbroke Grove/Kensal Gasworks, OOC).
Once you're at OOC, you have options. You could take over the Central Line service up the NNML, you could take over the freight lines down past Acton yard and boot the Central or the District out of Ealing Broadway and terminate there (so adding Acton Mainline, Noel Road (OSI with West Acton) and Ealing Broadway), or you could use the former GWR goods alignment along the NNML to Perivale, then run down the Greenford branch and then 6-track along to Slough/Airport Junction to bypass the Ealing Broadway to West Ealing bottleneck that prevents 6 tracking.
Crossrail could then just focus on Hayes and Harlington, Ealing Broadway, OOC and Paddington, and you could even perhaps argue against Ealing Broadway once OOC opens.
Basically, you start treating the H&C a lot more like the Metropolitan Line rather than the Circle Line, and Paddington Bishop's Road a lot more like Baker Street. If the Met can operate that many services into 4 platforms with conflicting terminal movements, then the H&C should be able to easily handle at least that many, if not more, and the GWML gets a high-frequency metro that can handle the suppressed demand along that axis far better than Crossrail's proposed jack-of-all-trades skip stop timetabling can.
