Nottingham 'Bus War'
Pigalle
27 Feb 2015
How long has that been so? I think existing agreements were allowed to continue, which is possibly why the Easyrider Anytime was never valid on trams when NCT was part of the consortium, but the green Easyrider was.
Both are relatively recent i.e. after the Competition Commission ruling. Off the top of my head I would say both are in the last two years.
Update: going back through the thread this is when it seemed to happen:
Kinchbus and TrentBarton are presumably already unified to accommodate this ticket:
https://www.smartgo.co.uk/images/EMA_supercommuter_poster.pdf
also it was promised in early - mid 2016 that the the electronic trentbartonland Saver tickets would cover both networks although I've never had any confirmation that this ever happened.
Interestingly it appears to have happened with the KinchKard equivalent if you buy a Kinchbus Universe and trentbartonland combined annual ticket, see here:
https://www.kinchbus.co.uk/kinchkard
I have contacted Trent Barton about this and they have confirmed that this is now the case; why would you keep quiet about such a good enhancement to your product from existing customers?
Pigalle
27 Feb 2015
That’s always the problem when a bus route is given up by a major operator in an area and replaced by a smaller company. Those who have to pay for their bus travel see big increases in fares for journeys involving more than one operator. That’s the advantage of those local authorities who have negotiated with the bus companies to provide multi operator tickets. Unfortunately the Derbyshire Wayfarer at £13 is very expensive, probably as a result of it also being valid on trains. Perhaps a cheaper bus only ticket in Derbyshire is needed. I’ve just returned from a few days away in Colchester and I found the £10 Essex Saver Ticket fantastic as it is valid on all buses in Essex. I wish we had something like that in Nottinghamshire.
It's not a smaller company though, just another part of Wellglade - they just choose not to accept TB tickets.
Clearly Trent Barton could chose to accept Notts and Derby tickets if they wanted to as they already sell / accept a plethora of multi-operator tickets:
https://trentbarton.co.uk/fares-and-tickets/joined-up-journeys
While nothing is the equivalent of a Zig Zag, they could at least offer the Red Arrow add-ons that they do for Derby Skylink, Derby Arriva, NCT and NET customers.
11 Sep 2012
uk
The Sevens, when they go to Notts & Derby, by not accepting Zig Zag, and if it is like the 12 which was the late Zoom, there will be a set charge to use Mango ie the cards don't actually work on the machine you just get a discount, but this won't be widely advertised, there will be no publicity available and gradually the service will drop in usage and timetable, until like the 12 it is withdrawn entirely.....
8 Mar 2018
According to a source on the derbybusdepot forum Notts and Derby will get two solos with the same ticket machines as trentbarton which will make using mango easier.
WillPS
18 Nov 2008
The great cascade begins at NCT on Monday, the 10-reg Omnidekkas on the Brown Line are replaced by Biogas buses. I presume these will then be repainted and refurbished for use on the 4, 34 or 100 (could also be the 48 or 49, but I think Enviro 400s from Turquoise on the 48 would make sense). Or are these in fact going to be withdrawn?
Next in line is the Lilac 27. Most of the Omnidekkas on here have now been rebranded in to the spare livery. I presume the last couple will be rebranded for one of the above routes too. This should then allow the remaining pre-2008 spares to be withdrawn.
I wonder whether a daytime frequency lift for the 100 is in order at the same time. Pretty much all the peak time ones are full as it stands.
goldisgood
5 Mar 2018
I thought that the 28 was next in line, and I think the only other confirmed route apart from this so far is the 68/69 although repaints of the 27 suggest that it will also see the gas buses. When the gas buses were announced the numbers were looked at, and it looked like it would be the 17, 27, 28, 58, 68/69, 77 and 89 recieving gas buses.
If those routes are correct, there would be enough Enviro 400s going spare for the Navy 48, 49 and Pathfinder 100 to see Enviro 400s, with the 4, 34 and 56/57/59 running with the newer Omnidekkas. The whole double decker fleet will probably only consist of gas buses and N230UDs, and I wouldn't be surprised if a couple of the older single decker spares were withdrawn.
ThatOneGuy
9 Dec 2016
There are eight routes due to receive the new Gas Buses. Four have been advertised publicly so far: 17, 27, 28 & 68/69.
The other four will be advertised in due course.
You'll probably find less cascading than might be expected.
WillPS
18 Nov 2008
Definitely the 27 next...
https://www.facebook.com/GbBusCoachEnthusiasts/posts/1088796191305762?hc_location=ufi - I believe there are now 2/3 19-reg Lilac biogas buses on site. I guess they could be planning a frequency increase for the 24/25/26, but that strikes me as less likely.
There are only 9 branded Enviro 400s (all on the 77) amongst those routes you mentioned to receive Biogas buses.
There are currently 8 Omnidekkas on the 48 alone. Unless the 78/79 Enviro 400s (or some others) are also cascaded, there isn't enough to cover the 49 or 100.
28 is due in the Summer. I guess since those will definitely be withdrawn it makes more sense to free up the vehicles they want to keep and cascade. That said, it does appear the 17-allocated Omnidekkas might be withdrawn. They have not been internally refurbished at all, nor stripped of their interior branding (which sometimes happens ahead of the vehicles being removed from service for repainting).
goldisgood
5 Mar 2018
There are also 9 on the 58 which are likely to be replaced this year. Looking at the comments further down that page, it is suggested that the 48 will see some Enviro 400s off the 58 or 77. There are 18 on these two routes, with the 48 needing 8, 49 needing 4 and the 100 needing 4.
EDIT: Just had a little look online. It seems like the order for the routes confirmed so far is Brown 17, Lilac 27, Purple 89 (towards the end of next month), Pink 28 (this summer) and Yellow 68/69 (this year). NCT have confirmed the 17, 89, 28 and 68/69, and as linked above the Lilac 27 buses are coming.
WillPS
18 Nov 2008
Quite right! Pardon my error.
In that case, it would probably make sense for those two routes to get their Biogas buses soon to allow 48, 49 and 100 cascades to happen over the Spring, then 68/69 early Summer to allow those vehicles to be rebranded (and upgraded?) ready for the 4/34 in September.
That would be the limit of any cascade then, Pink 28 Omnidekkas would be withdrawn (presumably late Summer?), Purple 89 Omnidekkas also withdrawn.
However you look at it it is one mighty bit of fleet renewal happening in a single year.
ThatOneGuy
9 Dec 2016
There are older buses to withdraw before the 89s, they'll be around for a few years longer!
You might find a few surprises coming up for the 49 too...
Robertj21a
22 Sep 2013
The new buses have now entered service - on the 17.
goldisgood
5 Mar 2018
There's been a press release confirming some of what's been said about the new buses.
https://www.nctx.co.uk/first-67-mor...s20m-investment-low-emission-buses-nottingham
The first buses entered service on Brown Line 17 between Bulwell, City Hospital, Hucknall Road and the City Centre this morning and will be followed by Lilac 27, Purple 89 and Pink 28 by the early summer.
Later in the year, five further routes will receive these low emission, environmentally friendly bio-gas double deck buses, increasing the total to 120 operating in the city by Christmas.
Lime 58, Yellow 68/69 and Turquoise 77 for 4 of those routes I'm assuming from this.
The arrival of the new bio-gas double deck buses enables NCT to withdraw just under 60 of its oldest diesel buses, as well as freeing up some of the younger diesel buses that have been fitted with the exhaust treatment system for re-deployment on to four other routes: Navy 4, Orange 34, Navy 48 and Pathfinder 100.
New biogas buses for the Navy 49 by any chance? That makes 5 routes - Navy 49, Lime 58, Yellow 68/69 (confirmed) and Turquoise 77.
ACBest
30 Aug 2011
Lincoln
NCT have announced this morning changes to the 49, which will see the Centrelink abolished, and Queens Drive park and ride served by the 49... and new buses!
https://www.nctx.co.uk/parkandride
Queens Drive Park and Ride site will be served by Nottingham City Transport’s Navy 49 service from 23 June 2019, with its existing diesel buses on the route replaced by a £1.6m investment in brand new bio-gas buses.
That takes us back to the situation of about 10 years ago when the P&R services were part of the NCT network. Very convenient if you usually used the bus but had to take a car in on the occasional day and could leave it at the P&R at no extra cost (in my case on the days when I had to drop my son at the nursery).
Funnily enough there's no mention of the free service within the city being abolished or retained but I bet it's the former!
The service was originally free in the city centre but became chargeable soon after the electric buses came in, due to council funding cuts I think. It has become free again due to the Broadmarsh works, presumably to make it easier for people to get to and from alternative bus stops, but I assume the plan was to make it chargeable again when the Broadmarsh was finished.
Wonder what will happen to the electrics and their charging facility next to the P&R...
howittpie
11 May 2012
NCT have confirmed in a response to someone on Facebook that the free bit in the city centre will no longer be free. Also interestingly they have also confirmed in another response that the 49 will not be an exact fare service and will give change.
Deerfold
26 Nov 2009
So we're back to the City Loop - but a rather worse frequency than every 2-3 minutes when all the Green Line buses ran on it.
ACBest
30 Aug 2011
Lincoln
At least every 5 minutes, which is where we’re at now, isn’t bad though really, is it? (Green 5-11 inclusive.)
Plus with the Navy 49 added in too, it’ll be a bit less than that at times.
Edit - and the Navy 4 (during uni terms) and Orange 34 come to think of it!
Deerfold
26 Nov 2009
Every five minutes, which is where we’re at now, isn’t bad though really, is it? (Green 5-10 inclusive.)
Plus with the Green 11 and Navy 49 added in too, it’ll be a bit less than that at times.
Edit - and the Orange 34 come to think of it!
Apologies - perhaps a bit long since I looked at the loop last.
kevjs
4 Sep 2013
And Turquoise 77/78/79 - with a different start/end point.... Does seem to have a lumpy schedule - all seem to arrive within about 4 minutes then nothing for the next 6...
UniLink 4 hasn't done the city loop since it came into existence
ACBest
30 Aug 2011
Lincoln
Totally forgot about Turquoise! I included Navy 4 because it does the railway station/Maid Marian Way to the general area of the Victoria Centre (ish - it’s a stones throw!), but I should’ve made it clearer what I meant, apologies!
11 Sep 2012
uk
The major inconvenience will be for those travellers arriving at Victoria Bus Station from the north (on the Threes, Pronto, SA etc) who want Broadmarsh/ National Express/ Railway Station who will now be facing a trek to Parliament Street for a bus to the south side of the city.
kevjs
4 Sep 2013
As a Preston born lad I've never really understood Nottingham's Public transport total lack of connectivity! Growing up with Western Europe's largest bus station a single bus journey away spoils you a bit.
It's not like the walking route between the Vic and Broadmarsh is particularly brilliant either.
SCH117X
27 Nov 2015
Odds on drivers of the 1313 Sat 49X from George Street getting teed off with punters for the park and ride getting on or trying to get on
Deerfold
26 Nov 2009
Most of the local services have very good connectivity - it just doesn't involve bus stations. I did think it was a mistake shrinking both bus stations, but most services never used either.
Statto
8 Feb 2011
At home or at the pub
Yep, the bus stations are mostly served by interurban routes, most of the local routes serve Friar Lane/Angel Row, then straight back out to the outer terminus.
Robertj21a
22 Sep 2013
It's certainly a bit surprising that there isn't a City Loop from the north. I would have thought that any of those Mansfield Road services could have looped round via Broadmarsh.
