Nuclear Power in the UK
Discussion in 'General Discussion' started by 14xxDave, 3 Jan 2020.
  1. 14xxDave
    14xxDave Member
    151
    20 Oct 2011
    Gateshead
    Mod Note: Please note posts #1 - #8 originally in this thread.
    Actually nuclear runs flat out all the time at 6.9GW, it's the only way it works. If you watch the grid then quite often coal does shut down at night but gas keeps going.
    Rail Forums
  3. Bald Rick
    Bald Rick Established Member
    10,523
    OT, but no it doesn’t. Nuclear varies in the long run as units are taken off line for maintenance or faults. It’s 6.9GW right now, a couple of weeks ago it was about 6GW, and for most of October around 5-5.5GW. This is from a capacity of 9.5GW.
  4. 14xxDave
    14xxDave Member
    151
    20 Oct 2011
    Gateshead
    But it does run flat out apart from refuelling and maintenance. Do you not agree?
    Oh and I thought the current nuclear capacity was 8GW?
  5. nlogax
    nlogax Established Member
    1,294
    Current UK nuclear capacity is somewhere around 9GW with a large drop-off expected in the next decade before the next generation of reactors are completed and operational.
  6. nlogax
    1,294
    Edit; I should really quote my sources. Chart 1 is what you need.
    https://assets.publishing.service.g...file/789655/Nuclear_electricity_in_the_UK.pdf
    "Nuclear electricity in the UK
    This article looks at nuclear electricity in the UK, examining how its position within the UK energy mix has shifted from the 1950’s to 2018, and how nuclear capacity is likely to change in the future."
  7. AlbertBeale
    AlbertBeale Member
    591
    16 Jun 2019
    Whether there ever will be a "next generation" of them is not a given.
  8. Bald Rick
    10,523
    It’s a racing certainty, albeit that generation may only be two strong, both based at Hinckley Point.
  9. 14xxDave
    14xxDave Member
    151
    20 Oct 2011
    Gateshead
    Well the red line as you would say on the rev counter is 8GW but what's a GW between friends. I also don't think we will have another generation of nuclear.
  10. Facing Back
    Facing Back Member
    106
    21 May 2019
    You think not? Well Hinkley C is due to last 60 years and EDF are - rather understandably - keen to use it as a blueprint for a new Sizewell reactor. There is a lot of research going on around much smaller, simpler reactors using quite different technologies and producing much less waste. And in 60 years who knows, the miracle of cold fusion may have materialised....
  11. GRALISTAIR
    GRALISTAIR Established Member
    3,544
    11 Apr 2012
    Dalton Georgia USA
    And then there is Thorium
  12. Facing Back
    Facing Back Member
    106
    21 May 2019
    Cheaper, less waste, breeds its own fuel and you can't use the by-products to make weapons.
    Only downside is as far as I recall the only semi-working example was 50 years ago.
  13. GRALISTAIR
    3,544
    11 Apr 2012
    Dalton Georgia USA
    Just requires the political will
  14. Peter Mugridge
    Peter Mugridge Established Member
    10,521
    8 Apr 2010
    Epsom
    That is probably why the politicians have shown no interest in pursuing Thorium reactors.
  15. Facing Back
    Facing Back Member
    106
    21 May 2019
    and possible a few billion in speculative investment.
    Which isn't totally impossible, I do know of some practical research which has been going on into "regional" thorium reactors.
  16. 14xxDave
    14xxDave Member
    151
    20 Oct 2011
    Gateshead
    I think you will find Hinkley C will never be built.
  17. 14xxDave
    14xxDave Member
    151
    20 Oct 2011
    Gateshead
    The thorium cycle is a nightmare.
  18. DDB
    DDB Member
    123
    11 Sep 2011
    You can use it to produce weapons or rather the theoretical method of producing weapons with it has been developed.
    https://www.popularmechanics.com/sc...uel-thorium-riskier-than-we-thought-14821644/
    Last I heard only the Indians were looking at it seriously and that was because they don't have many (any?) uranium deposits but do have plenty of thorium deposits.
  19. Puppetfinger
    Puppetfinger Member
    45
    18 May 2018
    Whilst I must admit to having limited knowledge, is greater research into Nuclear fusion the way forward, given this produces next to no waste, and removes the weaponisation issue? Also the sheer amount of energy produced would simply solve the Worlds energy generating issues.
  20. Facing Back
    Facing Back Member
    106
    21 May 2019
    That's true, it is possible and its been done but it makes poor weapons (at the moment) and the yield from a uranium fast breeder is over 50 times higher. Its also a quite multi-stage process which would (currently) need a different reactor to produce fuel than the produce commercial energy - which is not the end of the world for India of course.
    lol - I'm surprised to be having this discussion on a railway forum.
  21. Facing Back
    Facing Back Member
    106
    21 May 2019
    Very true. But Fusion research is very different to fission research though so both are conducted, its not an either/or. Fission research tends to be about incremental improvements whereas fusion research is about containment and how to do away with a fission element entirely.
    Fusion research is progressing but costs gazillions and last time I looked the fusion reactions they were creating took more energy required as input than was being generated as output and only for a fraction of a second. The good news is that its possible to produce a fusion reaction at all which wasn't the case a number of years ago.
    Agreed fusion power doesn't really change the weapons debate, we've already got fusion weapons.
  22. TrafficEng
    TrafficEng Member
    313
    13 Nov 2019
    North of London
  23. AlbertBeale
    AlbertBeale Member
    591
    16 Jun 2019
    Even the one currently going-to-be-built at Hinckley (in the sense that the actual reactor part is nowhere near being built yet) is far from certain to ever see the light of day. It's a new EPR design which no-one elsewhere has got running yet; similar ones elsewhere are well behind schedule and not certain to ever come on line. And given we'll all pay through the nose for decades to subsidise the cost of the most expensive electricity every produced, if Hinckley C does ever operate, then let's hope the plug is pulled [so to speak] as soon as possible.
    And as for the other (besides Hinckley) sites talked of ... that's really fantasy land, in my view.
  24. JamesT
    JamesT Member
    500
    25 Feb 2015
    Isn’t Hinckley Point the same design as the two reactors in China? One of which has been supplying power commercially for over a year now.
  25. AlbertBeale
    AlbertBeale Member
    591
    16 Jun 2019
    You'll be referring to the Taishan plant - that's an earlier version of the EPR and the only EPR design operating anywhere. (And of course there have been concerns that safety problems are more easily brushed aside these days in China in the race to install technology.)
    The only other EPRs - in France and Finland - are well behind schedule (10 years and 12 years respectively) with all sort of problems.
    The Hinckley EPR has itself been described as "the first of its kind" by its own people, albeit based on what they've so far failed to get operating in France and Finland.
  26. Facing Back
    Facing Back Member
    106
    21 May 2019
    I agree with some of this, the build at Hinkley is progressing and a lot has been done but there of years of work ahead. If it gets bogged down in huge delays and cost overruns then of course its sponsors could lose interest.
    I hope not. I agree to a large extent its the first of its kind but I'm afraid I'm an old fashioned engineering type and I think the UK should indulge in some world class first of its kind engineering.
    I do agree that the strike price for the electricity is very high - but I don't want all of the lights to go out if the wind isn't blowing and I think a balanced energy production base is critical as we move away from fossil fuels. As to whether any other reactors are "fantasy land" then I guess its wait and see. You'd expect the second reactor of the same design to be significantly cheaper/faster/less risky.
    The cost of renewable energy is dropping - who knows where the floor there is? And there is huge investment in energy storage. I think its entirely possible that these technologies will overtake fission in time which would potentially make future reactors redundant. But as I can't see a final decision on anything else for at least 10 years then I guess the powers will be able to assess the state of tech then.
  27. Meerkat
    Meerkat Established Member
    2,134
    14 Jul 2018
    I like the sound of the small reactors Rolls Royce want to make based on the submarine ones.
    Small enough to be prefab and trucked in. Less capital lumpy and theoretically quicker to set up.
  28. HSTEd
    HSTEd Established Member
    10,435
    Some of the remaining AGR units are licenced to refuel under load, albeit some only at reduced power.
    The travails of the AGR loading system are long and boring.
    For a long time the records for longest continuous run have been held either by British or Canadian reactors, although the Indians have now managed to pinch it.
    Heysham II Unit 8 did manage to remain on load for 940 days, which is approaching the statutory maximum of 1095 days before it was shut down for maintenance and inspection.
    Remember with nuclear your fuel costs virtually nothing and equipment tends to break when you switch it on or off, so the reactors are kept running whenever possible.
    The problem is Rolls Royce have no real experience on building civil reactors.
    And submarine reactors are hilariously expensive to build and operate, what with them being filled with bomb grade material.
    It is not clear they really have any relevant experience at all.
    The EPR is an example of what happens when you design a reactor by committee, trying to combine two designs with fundamentally different safety philosophies and neither side is willing to concede that their system is inferior. It's a terrible mash up of a Konvoi-type Siemens PWR and a late model French unit.
    That is why it has insane features like a core-catcher that are unlikely to significantly imporve the safety of the plant but cost enormous amounts to make.
    It is only being built at all because of French exceptionalism at EdF and in the French Government.
    AP1000 has problems with its pump shafts disintegrating in testing, and the plant is designed such that they cannot be replaced once the plant is built.
    The APR1400 is better, but it's been embroiled in scandals in Korea with faked cable approvals and the like, as well as the mess in the UAE caused by problems in actually training enough staff to start up the finished reactors.
    As someone proposing an emergency nuclear build programme in their PhD, it is a bit disheartening.
    (My provisional target is one gigawatt scale unit per month)
  29. Meerkat
    2,134
    14 Jul 2018
    Theres always some bloody expert coming along and ruining things with facts and science and stuff!!
  30. HSTEd
    10,435
    I'm currently neck deep in studies on reactor construction, trying to work out what designs are easiest to build given our currently technology base.
    Its an interesting but rather depressing field.
    But I think we can make reactors fast enough to make a big difference to carbon emissions in time to hit the 2C target.
    But I kinda want to requisition the contents of the Jaguar Land Rover plant....
  31. GRALISTAIR
    3,544
    11 Apr 2012
    Dalton Georgia USA
    I had as part of my Masters to do an essay and calculation of stress cracking caused by CsI (Caesium Iodide) on the zirconium alloy used in some nuclear reactors. Interesting field of study. Cs and I isotopes are often by products of nuclear reactions.
Share This Page
