Official Definition of Green
TheEdge
29 Nov 2012
Norwich
Just a query. Do the railways have an official definition of what green (and yellow and red) must be?
This stems from the fact that to my eye while the newer LED colour lights are clearly a very solid green older incandescent signals and semaphores sometimes look closer to a blue-green than actual green.
DownSouth
10 Dec 2011
The blue-green colour of older signals using coloured lenses is probably a carryover of companies having supplied railways with the same lenses as they supplied for road traffic signals, where blue-green is used for the benefit of road users who have red-green colour blindness.
If people with any form of colour blindness (red-green is the most common) are precluded from being train drivers due to not being able to fulfil the duties safely, a pure green can be used for rail signals
LED clusters on road traffic lights here in Australia have a mixture of blue and green LEDs in the cluster to achieve the correct colour, while LED rail signals are purely green LEDs.
t o m
7 Feb 2011
It's because the lenses on the old style signals are actually more blue than green. Incandescent lamps give off a yellowish light, not pure white like LED, so combined with the blue lens this makes a green.
A lens in a signal and a traffic light are both quite different. Traffic light lenses aren't designed to focus the beam in to the distance and they don't have a hot strip to focus the beam to the driver when close to the traffic light like a railway signal does.
ac6000cw
10 May 2014
Cambridge, UK
Yes there will be standards for colorimetry, beam shape, intensity etc. - there have to be to ensure consistency of performance between suppliers and across the network. Standards and specifications are the basis for any sort of quality control.
TDK
19 Apr 2008
Crewe
The official stance is Green, yellow and red. Some signals are slightly different in hue and are clearly more of a blue green than a true green but the terminology is green. Green is clear, 2 yellows is preliminary caution, single yellow is caution and red is at danger or stop.
snowball
4 Mar 2013
Yes but I think the original poster was asking about the standards that the equipment makers are required to work to, not the terminology used on the railway.
John Webb
5 Jun 2010
St Albans
May I gently point out that signalling companies were supplying railways long before road traffic signals were invented!
As explained by tom, the oil-lamps in signals gave a very yellow light, so the 'green' filter of a semaphore signal was, in fact, a blue one which combined with the yellow light gave green. When electric lamps were introduced into semaphores, the bulbs were deliberately under-run both to give a longer life and to retain the 'yellow' nature of the light, thereby avoiding the need to change the blue filter. In some of the remaining semaphore areas in the UK, LED lamps are replacing the filament bulbs, and either the LEDs are chosen to have a yellow tinge or the blue filter is changed for a green one.
LexyBoy
23 Jan 2009
North of the rivers
Good point on semaphores, I do recall that they have a blue "window" - makes sense now! (Don't think I've seen them lit, so hadn't occurred that it would give a green light).
Does anyone have an example (pic or location)? It seems rather inefficient to have a white LED lamp behind a coloured filter/lens, compared to replacing the unit with a dedicated LED signal.
<pedant>LEDs emit a very narrow wavelength, so emit "pure" green, yellow, red or blue, but never white. This is great for signalling as it means you're not wasting energy filtering out the unnecessary wavelengths. White LEDs have a blue-emitting diode with a phosphor coating formulated to look white to the eye - actually the emission is more "spiky" than black-body radiation e.g. incandescent or sunlight, which is why some colours look strange under LED lighting.</pedant>
"White" LEDs often look very white or even blue; this is especially noticeable with cheap ones. Partly this is because the better phosphors are more expensive or patent protected, but also because the eye is more sensitive to green/blue light so you get more apparent brightness for the same power.
Another advantage of LEDs for signalling is that the emission is very directional, so lenses are not required.
ac6000cw
10 May 2014
Cambridge, UK
Just out of interest, does anyone know if the UK standards (which would have been formulated when incandescent lamps + filters were the norm) have been modified to allow for possibly slightly different 'native' Red/Yellow/Green colours from simple LED's - to avoid having to use a filter as well to get an exact match with the old standards ?
(I'm thinking about colour light signal heads here, not converted semaphore signals).
W230
6 Jan 2012
I'd had also noticed this but never put two and two together! I think the semaphores on the line between Norwich and Great Yarmouth have blue "spectacles". :lol:
John Webb
5 Jun 2010
St Albans
As far as I am aware, the standard has some degree of latitude built into it, but for consistency the LEDs for modern colour light signals are chosen so that their spectral output complies with the standard and therefore matches existing sources, whatever they may be. Filters are not used.
Class172
Quizmaster
20 Mar 2011
West Country
All of the semaphore signals I have seen close up in my local area have blue spectacles - one signal just outside the station was recently replaced with a brand new semaphore (not colour aspect surprisingly), but it's hard to tell if that has a blue or green spectacle: I suspect the former since it's probably using the arm from the signal it replaced.
ac6000cw
10 May 2014
Cambridge, UK
Yes, NR seem to be keener on doing that - maybe they feel that it's better to keep all the signals in a 'box area consistent (whereas BR seemed to do whatever was cheapest/easiest sometimes !)
So the important question - does it have a GWR finial on top of the post ? ;)
6 Sep 2011
Blackpool south Shore
A reason of having a very blue green could it be that because blue has a longer wavelength than green, and would therefore travel further, especially in poor weather! Red has the longest wavelength. The old oil lights had a small flame - about half an inch high, and would burn for a week+ on a pint of oil, behind the focused bullseye lens.
Railsigns
15 Feb 2010
Blue has a short wavelength, shorter than green, yellow and red. Blue lights aren't good for long distance viewing.
ac6000cw
10 May 2014
Cambridge, UK
