"Open All Doors" function
6Gman
1 May 2012
How many units have an "open all doors" function? Issue raised in another forum whether traincrew could operate doors to avoid passengers having to press "door open" buttons in current circumstances.
aleggatta
28 Sep 2015
ISTR there was an instruction for the driver of 377's to operate the 'Doors open' button on 377's when arriving at Victoria and releasing the doors, mind you it may have just been a courtesy for those passengers slightly slower off the mark, but the button exists on Electrostars and is operated from the leading cab.
37057
3 Jul 2009
You might have to explain that to me. Leading cab only?
The control of opening all doors is via the TMS using the appropriate screen and soft keys. The TMS displays only function when keyed into a cab desk at the respective end so the guard won't have this control at the rear. The door enable buttons for the appropriate side still need to be operated before doing this.
The way this could work is guard steps off, checks train is in platform, enable the doors the normal way and then communicate with the driver to open them via his/her TMS. By that point I expect the passengers will have already opened their local door open push buttons though!
TFN
17 Aug 2017
I’ve definitely seen it on the GatEx 387s when some drivers opens all the doors a minute before departure
Pumbaa
19 Feb 2008
Mk4s. Useful when trying to find a sticky door that was preventing you from gaining interlock.
gimmea50anyday
8 Jan 2013
Back Cab
185s but only via the leading TMS display.
Well I must say I didn’t know about this, but then as the TMS has been deactivated in the inactive cab the usefulness of the TMS has been taken away from us tail lamps....
I do think however this should be an easily accessible feature available available to anyone with active door control. I think there should also be an option to close but not interlock the doors, although as most doors close automatically after a set time the need for this is much reduced but would still be useful
37057
3 Jul 2009
They were modified for reliability if I remember correctly, they'd often flag up with german warning notes!
Aictos
28 Apr 2009
Class 700s between London Bridge and St Pancras International via City Thameslink
37057
3 Jul 2009
Although I said 185s in my post it was the same on 350s too, so I expect all Desiros old and new have the ability via the TMS. It's used during the prep routine.
TheEdge
29 Nov 2012
Norwich
745s and 755s do.
I tried to use it to stop people from having to open the doors but you have to hold the door open for about 3 or 5 seconds by which time most people are already hammering away at the buttons.
driver9000
13 Jan 2008
That sounds like the doors test function and isn't used in service. The Guard has full control of the doors on the 185 and you're not describing how the doors are operated in service.
37057
3 Jul 2009
I know, I was describing how the doors could be used without passengers pressing buttons as per the original post. I also suggested why it wouldn't be very effective anyway.
gimmea50anyday
8 Jan 2013
Back Cab
The hard drives of the TMS computers were becoming corrupted because of the way a train is shut down )(batteries off button) doesn’t give the windows Based operating system time to shut down properly, so the HDDs were becoming corrupted, hence the German error messages. Because of the copyright of the TMS software it was apparently cheaper to link the shutdown of the TMS computer to the master switch than to reformat or replace the hard drives...
