Mcr Warrior
- Joined
- 8 Jan 2009
- Messages
- 15,002
Previously Metrolink advertised that their ticket machines accepted all bank notes and coins except for £50 notes and 2p and 1p coins.
Anyone know why at certain stations on the Manchester->Altrincham Metrolink line for example Sale (also Brooklands) it's now no longer possible to pay for tickets at the ticket vending machines using banknotes? (The slots have recently been removed/blocked up).
Robbery / Attempted robbery. Issue also afflicting railway machines, identical in build. Seems to be a (sensible) "do not replace as they'll try it again" policy. Annoying to J Public, but I understand why they've left it as it is.
They've now stopped use of banknotes at stations on the Bury line, including Bury Interchange itself.
I think Metrolink have built up a certain level of respect from people by making it quite easy to pay and by conducting enough ticket checks. Ticket machines being the only way to pay has meant they have been kept in good working order and are in sufficient numbers where they are needed.
But one's chosen payment method, out of those advertised as accepted, not being available is not annoying to J Public - it's a source of conflict. There are enough scum with no intention of paying a penny riding around on the trams as it is, certainly more than you can chuck off. Bad idea irking the ones who are trying to pay. If one cannot buy a ticket from a National Rail TVM, there will always be an alternative (including purchase at destination). Not so Metrolink, therefore it needs to be sorted.
:roll: Have now written to Metrolink HQ on this subject matter; currently awaiting a response!
they are trying to find a fix for the problem, and, that when they do, the banknote slots will be re-opened. So it does only appear to be a temporary problem
For those who are interested, a permanent fix seems to have been implemented. Further to my previous post, this is to reinstall the note intake but surround it with a metal plate which presumably blocks the slot where rejected notes would have previously left the machine. Most machines on the Bury line now have this fix, but I'm not sure about other lines. I've attached a photo so you can see what it looks like
This is obviously a good thing as it means that notes can no longer be blocked from coming out and stolen, but I wonder what will happen if a note is rejected?
My guess is that the machines will have been reconfigured for rejected notes to come back out the way they went in - S&B's rail ticket machines went through the same treatment a while back IIRC.
Can you get £5 of 5p coins into the machine? Especially at peak times.![]()
If any more machines are tampered with, would it not be possible to start prosecution of these people?
Metrolink said:Transport for Greater Manchester are working hard alongside scheidt-bachmann (*) to replace all of the damaged and vandalised machines as quickly as possible. The more feasible option at this stage would be to replace the whole machine rather than the mechanism. We do not have a specific date of when these will become available.
