All Line Rover
- Joined
- 17 Feb 2011
- Messages
- 5,263
Try Paddington to Reading at peak time, then you'll realise how feasible that is!
The local services are rammed, and take double the time.
This is the same situation for MK, LM services can't carry all of the MK passengers.
Why take a slow, rammed LM service, when you can take a quick VT one in half the time?
Evening peak LM services to Milton Keynes are not 'slow'. The 16:46 (trailing the 16:43 VT, which isn't 'pick up only' at MKC for some reason), the 17:13 (trailing the 17:10 VT), the 17:46 (trailing the 17:43 VT), the 18:13 (trailing the 18:10 VT) and the 18:49 (trailing the 18:43 VT, which again isn't 'pick up only' at MKC) all take 32 or 33 minutes. The VT services are timetabled to take 30 minutes but rarely achieve this is practice so the LM and VT services are in fact about equal. You can't compare Milton Keynes with Reading.
In an ideal world we would have a 125mph 12-car half-hourly service to Northampton calling at Milton Keynes only, taking 30 minutes to reach Milton Keynes, running throughout the day, and an end to the system of trying to merge two completely different commuter routes (Euston to Northampton via Milton Keynes, and Birmingham to Northampton via Coventry).
That he is allowed to, and will attempt to, does not follow that a prosecution would stand up if the passenger refused.
Has one succeeded?
Whenever I have seen a EUS to MKC passenger on a 'pick up only' train (which is virtually every such train where there has not been a manual barrier inspection at Euston), the guard has not attempted to charge the passenger.
Rather than expect guards to argue with passengers (or, alternatively, being happy to lose revenue, and allowing seats to be taken at the expense of passengers who have paid considerably more for a valid ticket), why can't Virgin ensure that there is a manual barrier inspection at Euston for every 'pick up only' train? These are all trains carrying hundreds of passengers who have typically paid £100+ each. They are entitled to expect Virgin to spend less than £100 on twenty minutes' pay for four or five ticket inspectors.
Those extra bodies on short journeys turn into non-revenue empty air after Milton Keynes. The goal is to add more capacity for the higher revenue longer traveller.
Which is a weak argument in the case of the changes which are being made from May, because they apply to trains which are off-peak throughout. On the 19:20 for example, passengers travelling from Milton Keynes to Stoke-on-Trent will have paid more per-mile for their off-peak ticket than passengers travelling from Euston to Stoke-on-Trent (but have next to no chance of getting a seat): Euston to Stoke-on-Trent is £68 for 290 miles return (23p per mile), whereas Milton Keynes to Stoke-on-Trent is £53 for 192 miles return (28p per mile).
If the goal is to ensure that higher revenue passengers are prioritised, why aren't departures such as the 15:10, 15:20, 15:43, 16:20, 16:43 and 18:43 from Euston (all trains where most passengers travelling from Euston to stations beyond Milton Keynes - at least as far as Crewe, Stoke-on-Trent or Coventry, as the case may be - will hold Anytime tickets), not 'pick up only' at Milton Keynes?
