Platform lengths
py_megapixel
5 Nov 2018
Northern England
Is there any good public source of information about the platform lengths at UK National Rail stations? This information seems a little hard to find
Thanks in advance for your help.
Edit: I am more thinking in terms of how many carriages could fit realistically at each station on the most common units, given that some sections of platform are unusable, have a ridiculously large gap etc. and that door positioning varies.
Clip
28 Jun 2010
Can the OP access those though which i think was the question
Joseph_Locke
14 Apr 2012
For me it was always "top of ramp" to "top of ramp".
But what if the "starting" signal is too close to the top of the platform ramp for the driver to see it? Signal standback is a TOC-led dimension, and varies by traction, so how can NR publish a platform length?
You end up with:
"The distance, measured along the platform edge, from either the top of ramp (TOR), end of platform fence or centre of the post of any main signal at the departure end of the platform to the top of ramp or end of platform fence at the arrival end of the platform."
Mag_seven
1 Sep 2014
here to eternity
Indeed and you can get bits of the top of ramp to top of ramp that are out of use. Thats why if any work to a platform is being considered (for longer trains for example) a location specific survey of the platform will be required.
Joseph_Locke
14 Apr 2012
Yes, but then the platform concerned would never be TOR to TOR; the SA/EAS are supposed to be accurate, and you're lucky if one is right, let alone if they agree ...
800002
19 Jun 2019
and not all parts of the Sectional Appendix show the lengths.
There be a table in each regions Sectional Appendix.
Does the OP want a particular station / region?
Also, incidentally, NESA is supposed to be the ultimate referece, which drives the input into the EAS/TPRs.
But Of course the TPRs are able to (and do) list operational capacity of platforms by specific operator / traction.
It is supposed to be the baseline but its full of a lot of garbage. The TPRs aren't always driven by it, if it flags an issue then ive known colleagues go out with a wheel to measure it (and thats top of ramp to top of ramp)
Bevan Price
22 Apr 2010
So you need a "useable" / "effective" platform length, discounting those parts infested by weeds, etc., and with no regular use?
Mag_seven
1 Sep 2014
here to eternity
A detailed platform survey as well as giving the basic top of ramp to top of ramp measurement would also record things like usable length, position of signals, signs etc
800002
19 Jun 2019
Presumably to get the useable meterage?
Although it is a tricky document to keep updated accurately - it does change more often than the TPRS are able to be.
Highlandspring
14 Oct 2017
Not in the Scotland Route SA there don’t be. To be honest I’ve always found the best way is to go out with the measuring wheel and chain it yourself.
800002
19 Jun 2019
Sir is correct. May I proffer my apologies for stating a clearly held assumption that all SAs were equal in their contents.
Although it does strike me as more than slightly strange.
Although section 5.4 of the TPRs does hold the requisite information.
