I present to you.... A USELESS RAIL REPLACEMENT
04:59 bus off Chester to Crewe:
https://www.realtimetrains.co.uk/service/gb-nr:V14495/2022-01-21/detailed
05:37 train off Chester to Crewe:
https://www.realtimetrains.co.uk/service/gb-nr:P21442/2022-01-21/detailed
Scheduled to arrive into Crewe within 3 minutes of eachother. Just cancel the bus and force everyone onto the train, same Arrival time basically. Save yourself a few hundred quid.
Next up:
23:30 bus off Crewe to Chester:
https://www.realtimetrains.co.uk/service/gb-nr:V14491/2022-01-21/detailed
23:30 train off Crewe to Chester:
https://www.realtimetrains.co.uk/service/gb-nr:P21083/2022-01-21/detailed
What an absolute waste of money this is!
I don't think you can blame bus/coach companies and their drivers for not taking rail replacement work seriously when the TOCs themselves don't. Well, those running long distance services might, but those running local services often don't. The driver is given a departure time from a particular point, with no acknowledgement of any train to connect with. Even departures from the bus originating point are often not supervised, and from intermediate points hardly ever. Often the driver won't know the route, especially if the bus has been brought in at short notice, but the TOCs don't see that as being their problem.
In the situation of a bus connecting with a train, the bus might wait, it might not, but in the converse situation, i.e. a train connecting with a bus, the train wouldn't wait in a million years.
P.S. The above is coming from someone who has done a lot of rail replacement work, as a coach driver.
This couldn't be more true. TOCs are awful when it comes to rails. The other week, TFW had a Manchester Picc to Manchester Airport service. There were other trains going which people could use, there was no need for the RRB, people could have switched trains and got there quicker.
I think for me, the worst thing now is TOCs not doing 'pick up' or 'set down' only. Pick up only helps for instances where a train is running behind but perhaps the TOC wants to save people changing trains. Say Manchester - Stockport (and beyond). Levenshulme and Heaton Chapel have a train 5 mins later but people travelling beyond, it saves them getting a train to Stockport then the bus. Anyone going to Levenshulme or Heaton Chapel would currently hear the announcement and go down and get the bus but that is daft when it is probably slower and who wants to be on a replacement bus if they don't have to be.
Set Down Only saves you serving stops which should not have passengers because the bus is significantly later than the last train. An example being this week the 23:12 from Crewe to Manchester is replaced by a bus. Northern have put on a train from Stockport to Manchester though at the normal times. In this instance, there is zero reason for anyone to get on the bus at Levenshumle or Heaton Chapel. as the 'last train' has ran. The bus should be set down from Stockport since the 'last' train has ran from these stations, only people travelling from south of Stockport should need to get to these stations. Set Down Only has so many perks and would reduce emissions and congestion as well as maybe cost savings (if the TOC paid 'actual' rather than 'scheduled' mileage). Above all else though, it saves passengers being sat on a bus longer than they have to which always goes down well.
Train companies seem to have little or no knowledge of the local bus network and, if they did, some RRBs could be dispensed with. In times of disruption local bus operators sometimes agree to accept rail tickets but I don't know what the arrangements are for reimbursement.
And if the bus is delayed in traffic the train certainly won't wait. I remember a train passenger giving the conductor/guard an earful for not waiting as the bus was just arriving and wanted to take his name!
So true. Local buses could and should be used for some rail rep, there is so much potential there, especially for some of the more local lines. I think though like many companies, TOCs frown upon local buses and love having the control which 'dedicated buses' brings. Also the thought of passengers having to walk an extra 100m for a a local bus rather than dedicated bus which stops at the station entrance. If Aber-Mach goes down though in the day, it has to be better to put people on the T2 or X28 as the buses are already there, half hourly (give or take) and serve all the stops except Borth (but a minibus could do that) and Dovey Junction (which Rail Reps can't serve so either way, people are stuck there). The T2 and X28 are quicker than the Rail Rep because of Borth (service takes 40-50 mins versus 55 on the RRB) so it's quicker, gets people moving without waiting for a RRB (except Borth) and when you go out to the public with the information, you can provide times for when the bus will be at the stop rather than emergency RRBs where you don't know how long it will take to get to each stop, you just guestimate.
