Points Questions
True. The UK seems to have an aversion to slips full stop.
Slips have diamonds, and mainland European railways are going down the same route of simplifying pointwork where possible, perhaps starting a few years later than we did.
Reasonable speeds are sometimes permitted on diamonds, such as at Greenhill Upper. https://assets.publishing.service.g...00017f/R042010_100318_Greenhill_Upper_Jcn.pdf
At about 09:45 hrs on 22 March 2009, train 2N50, the 09:17 hrs from Alloa to Glasgow Queen Street, formed by a three-car class 170 diesel multiple unit,
traversed Greenhill Upper Junction (figure 2) at 64 mph (103 km/h). One of the point ends, designated 125C, forming part of a set of switch diamonds, was in the incorrect position and the train trailed through them forcing them across to the correct position and damaging the mechanism as a result.
The permissible speed for trains crossing the junction to or from the Larbert direction is 70 mph (113 km/h); the permissible speed for trains on the Edinburgh and Glasgow line is 100 mph (161 km/h).
markymark2000
11 May 2015
Western Part of the UK
To your point No. 2.
One of the constraints in the design of turnouts and junctions on curves, such as that at Southcote Junction, is the degree of super-elevation ('cant') on the curve of the main routes. In this case the speed limit on the 'main' route - that from Reading West towards Newbury, is 60mph and the tracks are tilted towards the inside of the curve accordingly, see the illustration in this Wiki page. Each track is canted separately which means that the 'high' rail on the Up Newbury line line will be higher that the 'low' rail on the Down line. This means that any track from the Basingstoke direction a diamond crossing in the down Newbury line will have to be twisted so there are no 'steps' in the rails where the two lines cross and this will, of necessity, mean an even more severe speed restriction of the Basingstoke route.
By trying to place the turnouts on straighter lengths of track the significance of the super-elevation issue is reduced and having a series of single lead points enables the civil engineer to match track geometries better. In the dim and distant days when Southcote Junction was a double junction with a diamond crossing the speed limit towards Basingstoke was (IIRC) 40mph (and may have been less - I'm trying to remember what it was like 40 years ago and more) and that on the Newbury route was 50mph. So the present layout is a definite improvement.
As to your point about about time loss, in the particular instance of Southcote Junction this is minimal. On the Newbury route from Reading West the speed limit is 60mph from the northern end of the platforms to past Southcote Junction and the speed limits on the turnouts to the Basingstoke line are 50mph southbound and 45mph northbound. So southbound trains have to lose 10mph and northbound ones can't be running at more than 60mph anyway as they join the main line - a 15mph difference. The container trains, running roughly hourly in each direction, are limited to 30mph between Oxford Road Junction (at Reading West) and Reading West Junction on the Relief lines to Didcot - in view of their weight the southbound trains won't have changed speed much between Reading West and Southcote Junction so the effect of the speeds at Southcote Junction on their running times will be very small and the northbound trains will be braking for the 30mph turnout at Oxford road Junction. Trains calling at Reading West will not be running at line speed so the trains which are most affected are the one or two per hour Cross Country services which are non-stop between Reading and Basingstoke.
All engineering is a compromise between several competing factors. In this case I would suggest that the engineers made the correct call.
Thank you. This is very detailed and helps a lot.
The times I have noticed the speed decrease most was towards Basingstoke on the GWR service and they definitely lost more than 10mph (I would say probably about 50 down to around 30 until just over the junction and then sped back up again). It could have been a TSR or something but it happened a few times so I thought it was more permanent. Northbound seems faster but less comfortable with the way the points are.
civ-eng-jim
16 Jul 2011
Derby
The approach control to junctions is sometimes a bit rudimentary (Thinking along the lines of approach release) reducing the approaching train to a speed that's far lower than the capability of the turnout.
coppercapped
13 Sep 2015
Reading
According to the June 2019 issue of the Wessex Route Sectional Appendix (can be downloaded from Network Rail's website as a pdf) there is a permanent 45mph speed limit in the Basingstoke direction from 37 miles 76 chains to 38 miles 8 chains, this is just south of Southcote Junction. The limit then increases to 75mph until the outskirts of Basingstoke.
In the northbound direction the 75mph line limit drops to 70mph at 39 miles 5 chains and drops again to 45mph at 38 miles 8 chains.
I don't know the reasons for these short speed limits, but I note they are all in the Wessex route area, the boundary between the Western and Wessex routes being at 37miles 76 chains.
Regarding the comfort. Southbound towards Basingstoke the trains run over only one turnout, northbound from Basingstoke over three. Going to or from Newbury the junction is scarcely felt.
Those PSRs are for the junction. The junction isn’t shown in layout form in the KSW Sectional Appendix as it is ‘off patch’.
MarkyT
20 May 2012
Torbay
The industry has got better at this, with flashing aspects and the return of the splitting distant, as well as faster turnouts. In the case of Southcote Jn, in the down direction the speed to Newbury is 60mph while the divergence to Basingstoke is 50mph. Because the difference in speed is no greater than 10mph there is no need for any form of special junction signalling controls. However with electrification of local services to Newbury there is a risk of a local EMU becoming marooned on the yet to be electrified Basingstoke line in the event of a misroute. I have no access to details of the new signalling in the area, but the divergence would be a good candidate for some sort of advance junction information to be provided for drivers nonetheless, such as a preliminary routing indicator (PRI).
coppercapped
13 Sep 2015
Reading
In which case I'm confused...!
The Western and Wales Sectional Appendix shows Southcote Junction at 37 miles 62 chains; going south towards Basingstoke that's 14 chains before the boundary with Wessex. There is no 45mph limit shown on the southbound line in the WW SA, this limit is only seen in the KSW SA and it starts at the boundary. The PSRs for the junction in the WW SA are 50mph to Basingstoke southbound and 45mph from Basingstoke northbound.
I'll have to go to have a look!
Sorry I misread your post.
The junction is 37m62c
The route boundary is 37m76c
It’s 50 through the junction itself, then 45 round the curve beyond it. Possibly to do with signal sighting of BE501.
MarkyT
20 May 2012
Torbay
I suspect the turnout speed was chosen to avoid the need for any approach release in the signalling.
coppercapped
13 Sep 2015
Reading
Ah! That could well be the answer!
EvoIV
23 Jul 2013
After the junction at Southcote there is indeed a short section of 45 after the 50 before the speed goes back up. The general consensus is that this is an old artifact from the fact it is right on the regional boundary in the sectional appendix and it is not boarded or observed by anyone that I know of. There are many errors in the sectional appendix but that's not surprising as it's such a complicated and jumbled document. There is no preliminary indication of the route at Southcote but the sighting is pretty good so not really an issue so long as you look ahead in good time.
