Porterbrook Cl.769 'Flex' trains from 319s, initially for Northern
978wta
5 Dec 2017
Huddersfield
I can't hear the rear unit doing anything in that video - only sounds like the front one is powered to me?
I thought the same as you can definitely hear the Diesel engines along with the traction motors on the first set but not so on the 2nd set.
It could be the way the camera has picked up the sounds or was it simulating a drag??
AM9
13 May 2014
St Albans
I thought the rear one was the most noticeable, sounds like it's just coming on to the turbo?
I agree with samuelmorris, assuming the driver didn't shut off the power as he passed, th motor whine only came from the first unit. Listening for the noise from the engines can be misleading as their power demand is determined by the draw of power from the generators, but the speed it's control sets to supply that power may not always be the same.
samuelmorris
18 Jul 2013
Brentwood, Essex
Even at idle you'd expect to hear at least some noise from the rear unit, I really don't hear anything, having rewatched it, only rail noise from the rear unit.
modernrail
26 Jul 2015
The track on that video looks to be in a bit of a state. Is that the Southport line and is that pretty poor track or just a trick of the light/camera angle etc?
Mogster
25 Sep 2018
Surely not, they wouldn't put out sufficient power without them. It sure sounds like a turbo is in operation in that video.
I thought the lack of turbocharging was responsible for the only moderate power available to the motors on diesel?
This is only from info on here over the years, may be wrong.
I got the impression the amount of power on diesel was less than on electric but still pretty reasonable for a diesel - performance is claimed to be at least as good as a 4-car 150.
a_c_skinner
21 Jun 2013
That was the claim of the initial modelling over the Buxton line IIRC. Mind you that may differ from actually driving one up there.
Agreed, but the initial modelling wouldn't have given that result unless the installed power was comparable (so one Flex engine raft is worth two Sprinter engines).
Greybeard33
18 Feb 2012
Greater Manchester
Which indeed is roughly in line with the gross engine power output figures (2*390kW on a 769 versus 4*213kW on a 4-car 150).
northernbelle
10 Oct 2018
It wouldn't surprise me - all the recent rolling stock testing and validation I've been aware of in recent times has had to include a 'drag' scenario - Hitachi chose Dainton Bank between Exeter and Plymouth as the location to test a dead 5-car IET being started away by another on the severe gradient.
samuelmorris
18 Jul 2013
Brentwood, Essex
520hp is still a fair amount of power to get from an engine, to get that without a turbo it'd have to be enormous, not something you'd fit underneath the passenger compartment, it'd have to go in a power unit cabinet like on a 755 or a thumper. Using turbochargers on large diesel engines has been standard practice for many years.
AM9
13 May 2014
St Albans
Surely it isn't just about the absolute power the installed engine can give. There's differences in overall unit weight, (nearly 160t for a 769 vs about 144t for a 150), then there's the gearing of the units, 769 is for 100mph vs 150 for 75mph. Those two both weigh against the 769s, but the torque/output speed profile of a diesel engine/generator/DC motor is far more flexible than that of a diesel engine/torque converter, so there are reasons to believe that even in a stopper role, the 769 may be no worse than a 150 and probably a lot kinder to the engine in service.
One thing that has so far not been mentioned here is that when a 150 (2-car) has a failed engine, not only is the tractive effort halved but so is the adhesion. On the 769's case, although if 319 experience is to go by, motors do get disconnected for various reasons, they are generally getting an easier life in the north-west so that is less likely, however if an engine fails, performance would of course hardly be stellar but adhesion would not change at all so a limping home train is unlikely to completely stall on difficult gradients/railhead conditions, (unless the 750VDC bus is split between pairs of motors when running on diesel).
AM9
13 May 2014
St Albans
And on smaller ones, although diesel engines in new cars are nearing the end of their useful mass sales life, the turbo option is virtually universal.
samuelmorris
18 Jul 2013
Brentwood, Essex
Sure, I only qualified large engines as when you cover small you get to things like portable generators, cherrypickers etc. that probably don't have them.
Bertie the bus
15 Aug 2014
They're not testing them. Testing is supposedly complete. They are now doing driver training in preparation for entry into service.
Grannyjoans
29 Mar 2017
While these 769's are a long way off a 195/331 or even a 158, they've got to be an improvement over 150's.
Mogster
25 Sep 2018
More carriages from Southport of any flavour will be an improvement...
People suggest that a 319 is significantly better than a 150 as a passenger, I don’t really see much difference. I think it depends on wether you prefer the predominantly bay seating the 319s tend to have. For all their problems inside a 195/331 is a far nicer place to be than on any of Northern’s other stock.
Grannyjoans
29 Mar 2017
I thought some of the better 158's are just as good from the passenger point of view
anamyd
17 Aug 2018
The engines definitely still have the turbos and intercoolers; that matches up with the 523hp rating from a 12.8-litre Diesel straight six. Also, I don't think "optional turbos" have been a thing on big Diesel engines since the 90s, and at that on smaller (6-litre-ish) road engines e.g. Cummins 6B vs 6BT. Naturally aspirated (so-called "non-turbo") engines haven't had new-build rail use since the 1st gen DMUs.
What I'm now not sure about is how many engines have been fitted under each of the units' two trailer vehicles. I was under the impression that it was one engine per trailer vehicle (two engines per unit) but the Wikipedia article is stating two engines per trailer vehicle (four engines per unit) - which is right...?
