Pre Beeching Atlas
philabos
19 May 2010
Lancaster PA
Seeking advice on the best one to buy.
Already have the pre Grouping but it is bit hard to read.
Choices I have seen are the British Rail Atlas Last Days of the Big Four 1947 or the British Railways 1955. Any recommendations?
John Webb
5 Jun 2010
St Albans
I have both - the "Last Days of the Big Four" is not as clear to read as the 1955 version due to the version of the underlying map used, but includes railways closed pre-Beeching, of course. They all would be better in an A4 format, but the series have the advantage that they use the same pagination for easy cross-reference between editions. I tend to use the Pre-Grouping and the 1955 editions more.
You might want to look out for C J Wignall's "Compete British Railways Maps and Gazetteer From 1830-1981", published by Oxford Publishing Co in 1983. This is A4 sized, but the pagination is awkward; there are also some known errors in it, I have been told.
pdeaves
14 Sep 2014
Gateway to the South West
I understand that there are more than 'some' known errors. It has the feel of having been drawn entirely from memory! It's a shame as it had the potential to be really helpful.
Bevan Price
22 Apr 2010
Yes - Wignall atlas was a good idea, but suffers from what appears to have been very inadequate proof-reading.
If you can afford separate atlases, the GWR Atlas by R.A. Cooke is excellent for that railway.
Ian Allan recently published a Southern Railway atlas which seems to be quite good. Sadly, I know of nothing similar for LMSR or LNER.
DavidGrain
29 Dec 2017
I don't know if it is still available but I have used nothing but Jowett's Railway Atlas for years, leaving aside the other atlases that I have had in the past. Have just checked Amazon and they have 7 second hand copies from £29.94. A fantastic volume as all the maps are hand drawn and the lists of stations, junction, tunnels etc all listed by hand.
pdeaves
14 Sep 2014
Ooh, I didn't know about the Southern one. Does anyone know of an image of a sample page? I can't tell from Amazon whether it's one I would want to get or not!
Bevan Price
22 Apr 2010
If you cannot find an image, please send me an email and I will photograph a page (off forum).
([email protected]).
philabos
19 May 2010
Lancaster PA
Thanks very much for the recommendation. Looks like exactly what I am seeking but could not find myself. At 352 pages, must be quite detailed. I see the same firm also has a "Rail Centres" book which I assume covers terminal areas in detail.
Bwlch y Groes
22 Jul 2017
The 1955 one is the first one I bought when Ian Allan first started selling them. It's very good but it was only later that I found out how many lines had closed between the end of the war and 1955, so it's never quite there in terms of being the network at its biggest
Colonel Cobb's atlas is the ultimate but the current edition is a lot more expensive than when I bought mine
Bevan Price
22 Apr 2010
I forgot to mention the Midland Railway System Maps, reprinted a few years ago, which show detailed maps of the former Midland Railway which became part of LMSR in 1923. Not sure if they are still in print. Also included joint lines (LTSR, M&GNR, S&DJR), and some lines over which MR had running powers.
http://www.midlandrailway.org.uk/maps/distance-diagrams.html
Somebody also started a project on LNWR lines, but only the Northamptonshire volume was ever published (and strangely described as "Part 5")
Xenophon PCDGS
17 Apr 2011
I brought Then & Now atlas by Paul Smith & Keith Turner, has maps from 1923, then compared with 2012.
For some reason, I have two hardback versions of these. One has a red, yellow and white cover (marked 2nd edition) published in 2015 and the other one has a pale blue, dark blue and white cover, published in 2012. Both showing the imprint of Ian Allen Publishing
etr221
10 Mar 2018
On line there is Rail Map Online http://www.railmaponline.com/UKIEMap.php - has historic and modern layers, with annotations available; and, downloadable as a PDF the New Adlestrop Railway Atlas http://www.systemed.net/carto/new_adlestrop.html ,but this only covers the southern half of the country.
The NLS has various editions of OS map on line showing the pre-Beeching network - I look at the 7th Series One Inch (late 50s/early 60s) a lot: https://maps.nls.uk/geo/explore/#zoom=13&lat=51.5117&lon=-0.2129&layers=11&b=7 is what I have book marked - explore and enjoy what else they have. And there are other sources for similar maps...
