problem at Bedhampton LC
pompeyfan
24 Jan 2012
just been stuck at Bedhampton LC for quite some time, NR guys present, all trains stopping and using the horn before proceding, and barriers eventually raising a good 2 mins after the train cleared the LC
tsr
15 Nov 2011
Between the parallel lines
Delays are currently showing of up to around 3 minutes.
Did you see if the level crossing was in any way operated manually before the train passed over? I'm guessing you may not have done.
As for the horn - I would say that's a pretty normal thing to hear if emergency engineering works are going on and workers are on or near the track.
