Problem with deleating sound folders
nutter
13 Nov 2005
Albrighton, Nr. Wolves, Shrops
I can delete individural files, but can't delete the folders which contain the files, even when they're empty. I get this error message
"cannot delete xxxx:it is being used by another person or program
close any program which might be using the program and try again"
I'm not on BVE at the moment so nothing should be using it, and it says this with empty folders.
I'm re-installing BVE due to mucking up the directories and having different versions of routes all over the place, to avoid using the wrong version.
This problem only occurs with files that do or have contained sound files. Please help
Craig
15 Jun 2005
Newcastle
During the boot procedure press F8 repeatedly until the XP Advanced Options menu is displayed, then select safe mode.
H
HR2
Guest
If you can rename the folder then do so by adding 'old' to the name. [before any suffixes] You should then be able to delete it.
devon_metro
11 Oct 2005
Otherise you have a program which is using them. So basically you want to get rid of it as that would most probably be a virus.
Craig
15 Jun 2005
Newcastle
BVE could also still be running in the background, which sometimes happens with me. Open the task manager and go to processes. If bve.exe is in the list, click it then click end process.
nutter
13 Nov 2005
I've solved it, i couldn't get safe mode to work properly (wouldn't even show the scan disk) so i logged on as my dad, deleted everything in task manager except system components and taskmgr and explorer and it worked.
something else must have been using it. now is the long re install of all the british stock, oh boy, it's going to be a long night
BTW, is there any 'real' french TGV routes with a tgv in english
nutter
13 Nov 2005
well we;re both admins, i think it's a case of my dad has alot less stuff allocating to his area of the hard drive, so the cpu could think about it more, and so delete it. He normally 'taps' into my area to play things like BVE and simsig
