radio frequencies
ralphchadkirk
20 Oct 2008
Essex
If you mean NRN and CSR then they are definitely secured. Radios used for things like shunting are also likely to be on private scrambled frequencies.
DaveNewcastle
21 Dec 2007
Newcastle (unless I'm out)
The general information about frequency allocations (along with modulation types, permitted radiated power, channel widths, etc.) for radio frequencies used on the Railways can be found on the Offcom website.
If that wasn't detailled enough for your purposes then I would be wonderng why you wanted to know.
Trainspotmatt
24 Apr 2012
im just curious and wanted to know if they could be tuned into or not for my use only nothing more.
Tracked
30 May 2011
53.5440°N 1.1510°W
the local main station to me can be picked up on 453.55mhz, from memory there is/was in cab frequencies around 205-207mhz, if that's any help
big_dirt
16 Feb 2011
Is there any reason why an enthusiast should not listen in?
When I was younger I used to have a flight band radio which went up beyond 108FM. I was able to listen to air traffic control and also some police frequencies.
As I grew up in Belfast, I used to get the radio out when there would be bombscares in town.
Anyway, I can understand the police wishing to have secure communications but why the railway?
michael769
9 Oct 2005
No practical reason other than that with the advent of digital communications it is largely becoming technically impossible for the amateur.
As recently is the 1980s it was possible to listen into the fire and police radios with nothing more exotic than a FM radio receiver - the world did not end and criminals did not have a field day.
wintonian
15 Jan 2010
Hampshire
Indeed, I belive it is common in the states for people to listen into the railroad frequences, and they can be listened to online, which would be illegal to do here.
jopsuk
13 May 2008
Though they've alll moved to ever more secure systems- and obviously the railways are shifting to GSM-R now.
michael769
9 Oct 2005
The move towards secure systems was driven more by the long term desire to transmit data along with voice. Once one starts to transmit data the nature of information being transferred changes, and the need for security increases. Few would be comfortable with the idea someone with a scanner being able to obtain a complete copy of all their personal details including medical history!
Likewise GSM-R is a prelude to the long term goal of cab signalling, and we most definitely do not want folks to have the ability to control a train's signals with something bought out of Maplin!
Safety365
8 Dec 2010
Even if you could tune into the Cab Secure Radio, you wouldn't be hearing much of interest.
Example:
Driver: Good Morning Signaller, This is the driver of One-Whisky-One-Five (1W15) currently at a stand at Whisky-One-Two-Three on the Down Main Fast on approach to Clapham Junction.
Signaller: Good Morning Driver of One-Whisky-One-Five, This is the signaller of Wimbledon panel number one, area four-zero. The reason I've stopped you at Whisky-One-Two-Three is because of a track-circuit failure....
At this point I have lost the will to carry on. You will not hear boring conversations like this. If you were able to hear these conversations, you wouldn't be hearing them very often. Unlike commercial aircraft, we rarely need to talk to the signaller. Obviously aircraft talk to Air Traffic Control, not a signaller...
If you want to use your radio to listen to something interesting, may I recommend BBC FiveLive
starrymarkb
4 Aug 2009
Exeter
And don't drivers use the signal post phones for routine stuff.
Also ATC is starting to go down the data route. Oceanic and Pre Start clearances at major airports are often transmitted over ACARS
Cherry_Picker
18 Apr 2011
Not if you have CSR or GSM-R fitted.
Most stuff transmitted over radios is quite routine and would probably be rather boring to listen to. You should be able to hear a lot of it in a scanner if you want to though.
Andrew Nelson
28 Jun 2010
I picked up the radio the other day while waiting outside Hebden Bridge with a Track Circit failure.
I was listening to Radio4 at the time.
lincolnshire
12 Jun 2011
Example:
I agree with Salop Sparky its the most boring thing to listen too, even listening to aircraft is far more interesting and thats bad enough, suggest you find something else to do with your time instead, how about train spotting at a station at least it gets you outside.
