L&Y Robert
I have been reading RAIB reports they are full of interesting stuff. However, one of them (R242014-141113-ECML-Rail-Breaks.pdf) deals with broken rails, and documents several instances of rail breaks occurring at or around fish-plate joints. I have often wondered about this type of joint, used throughout our railway system. Their numbers have been much reduced in recent decades by the introduction of long welded rails, but they are still predominate on some lines and are common around points and crossings and so-on. The butt joint seeks to unify two lengths of rail which are effectively jointed by clamping two additional short members (the fish-plates) to the rail web, one on each side, using four (now six, I see) nuts and bolts. The rail ends thus clamped are themselves short cantilevers from the last point of support - the preceding sleeper. This arrangement is then repeatedly subjected to rolling loads of varying intensity but of short duration as the wheels of a train pass over, producing intermittent bending moments and shear forces in the rail ends. I see that the clamping action between rail head and rail foot of modern fish-plates will, to some extent, transfer the deflection of the roll-off rail to the roll-on rail, and then, as the wheel passes over, the reverse. Nevertheless there is - must be - some residual bending moment in the rail end, and pictures in the RAIB of rail-end failures support this. An added complication is that the rail web has to be drilled to admit the fish-plate bolts right where the forces are greatest. One day at the Ffestiniog railway I saw that the butt joints of the original railway were made in a different, and in one respect to my mind superior way. The ends of both rails were arranged to fall centrally in an extended chair, secured to a wider sleeper, and held in place there by wooden keys. The wooden keys might be a bit doubtful, but the point here is that the rails are supported right to their very ends, so do not become cantilevers. Bolted fish-plates could be used in such an arrangement, but the rail would be fully supported at the joint. For this I envisage some kind of combined chair/base-plate/fish-plate fabrication and a wider sleeper perhaps even a single longitudinal sleeper (well, itd be a pair of course, the other rail as well sort of H configuration). Maybe its been tried, but if so Ive never come across it or heard about it. What do we think?
