D6130
The West Clare?....borrowed from the Co. Donegal?
Good guesses both, but not right. However one of them is close.The West Clare?....borrowed from the Co. Donegal?
You are getting very warm in terms of the location of the journey, but the provider of the gear (actually I think only a directors' saloon poshed up for the occasion) was a good few miles to the east.It seems that the Royals' 1903 tour prominently featured the north of Ireland -- was the Royal Train provider, the Co. Donegal Joint; borrowing the gear from the Londonderry & Lough Swilly?
Ballymena & Larne s source of the gear used?You are getting very warm in terms of the location of the journey, but the provider of the gear (actually I think only a directors' saloon poshed up for the occasion) was a good few miles to the east.
That's correct. And the railway it was lent to for the occasion has been mentioned, but not as the operator of the train. Who can put the two together?Ballymena & Larne s source of the gear used?
Afraid not, but a good try.HS1?
Paisley Gilmour Street - Gourock?
D6130 correctly identifies the MK 2 ole, unique to this line. It was a follow on to MK 1 that was immediately superseded by MK 3, and never used anywhere else. Over to you old friend.Paisley Gilmour Street - Gourock?
Thanks @McRhu !D6130 correctly identifies the MK 2 ole, unique to this line. It was a follow on to MK 1 that was immediately superseded by MK 3, and never used anywhere else. Over to you old friend.
Correct! There is about half a mile of minimum height catenary either side of the end of the runway, with trip wires operating in the manner which stated. You're clear for take off with the next question.Would it be to do with the 'Trip Wire' at the end of Glasgow Airport runway, which I believe cuts power to the OLE as well as setting signals to Red in the event of an aircraft running off the end of the runnway?
Well, I would have said the Glasgow Suburban system with the 311s as a first guess, bur weren't the recently retired Isle of Wight units built by Cravens?
Regards
Ian
The 1986 built trains were made by Severn Lamb ( and the earlier ones used up to the 1970s by AC Cars of Thames Ditton ) - so afraid not, again.Southend Pier? 2015?
...until when...?The Metropolitan Line?
About ten years ago -2012 or 2013?...until when...?![]()
That'll do nicely - yes, it was 2012 when the Metropolitan Line A Stock was withdrawn, and this was the last Cravens stock in everyday use in the mainland UK.About ten years ago -2012 or 2013?
