In the theme of "The next station is......" but based on lines rather than train services. Each move can be to any location on the same line that has not already been posted. Where the last move is to a junction you may move to a location on any of the lines from that junction. Stations, junctions, loops and the end of the line even if there is no station there are all valid moves. No going into sidings or depots.
For a move, post the Engineer's Line Reference for the line you will be using and the location you will move to (for example MLN, BML or VTB full list at http://deaves47.users.btopenworld.com/ELRs/ELR0.htm) for this game changes of mileage do not change the line you are on so you need only state MLN to move from Paddington to Penzance. Sections 1-4 of MLN do not count as separate lines. However where a line has two sections broken by another line you may only go as far as the end of the seciton. For example on SWM you can only go as far as Standish Junction.
The game ends when there are no more valid moves available from your location.
The game will start at MLN London Paddington.
