Reading Station
96tommy
18 May 2010
I am going to Reading hopefully next Friday. I have never been before but I wanted to know what trains go there and how much freight goes through.
Thank You
fgwoll1e
5 Jul 2007
Turbos, Voyagers, HSTs, Junipers you may see Desiros depending on what SWT are using on the Reading - Waterloo line.
Reading does have it's fair share of freight passing through too :)
Drsatan
24 Aug 2009
Land of the Sprinters
If you want to see Freightliner trains heading to Southampton go to Reading West station. This is because they take the Reading West curve which avoids Reading station.
96tommy
18 May 2010
Thanks for the information!! What is the freight mostly I will be staying there around 2/3 hours 12-14:30, do you think at least one will go through
Metroland
20 Jul 2005
Midlands
The Southampton bound freightliners go round the curve the other side of the station almost out of view, you'd have to see them at Tilehurst to get anywhere near them.
kestrel
27 Oct 2006
Head for Reading West, always good about that time for FLi's plus you'll get all the usual HST/Turbo/Voyagers and some 59's;)
For food drink etc there's a mac's next to the stn;)
12 Feb 2010
Taunton
Just remember to take precautions like a stab vest. Reading West is in a less than salubrious area, where druggies & robberies are common.
LE Greys
6 Mar 2010
Hitchin
Usually expect one Merehead-Acton stone train coming up from the Berks & Hants. They sometimes do a big crossover move onto the up relief, which blocks the down main for five minutes and probably explains why they want to put in a diveunder. The empties go back the other way (naturally). Either should produce a 59.
GearJammer
12 Nov 2009
On the Southern
For that reason alone i would avoid Reading West, its not worth it for a few Freightliners and i should imagine it gets a tedious between trains, where as at Reading itself theres always something going on to keep you amused but it depends what you want to see, if you want the Freightliners then if i were you i'd go to Didcot, if you don't mind missing them then stay at Reading itself and enjoy the stone trains and the HST's!
TGV
25 Nov 2005
320km/h Voie Libre
I'd suggest this - stay at Reading for a half hour or so and see what you see. Then jump on a Basingstoke service (Either Cross Country or GW), it only takes 20 minutes or so. Once at Basingstoke, you'll see a whole lot of other stuff including... your Freight services crossing over the SWML en route to/from Southampton. Then once you've seen one, jump back on a Reading train and jobsagoodun.
B'stoke station has loads of services too - coffee, restaurants, WHSmith, etc.... much better choice than Reading West.
