[Resolved] When to use an off-day return?
AstowJ
30 Dec 2022
Bristol
I apologise that this is probably a very dim question
I recently bought an off-peak day return ticket via trainline, and have set times and trains that I specified.
I want to travel earlier now to see a friend: can I still use these tickets? When does on-peak become off-peak?
I wanted to travel at 6pm and now want to travel at 5pm
ashkeba
13 May 2019
Look at the restriction code printed on the ticket. Should be nre.co.uk/ and two letters or numbers. Put that into a web browser.
Peak and Off-Peak is determined by the ticket not by the train. There is no blanket peak/off-peak distinction (as much as some TOCs like to pretend there might be).
If you could tell us the journey being made, the ticket held and whether you are on the outward or return portion we should be able to advise.
AstowJ
30 Dec 2022
Bristol
Filton Abbeywood to Cardiff Central:
I originally wanted to get on 1806 and booked this, and plans changed and I may get the 1707 or 32
I always assumed off peak day return was just for the return journey and the outward was set in stone, and only now am I questioning it.
Sorry,
The ticket held is an Off Peak Day Return via Newport
Sorry,
Aha, that has restriction code W1 which reads "Not valid on trains timed to depart after 04:29 and before 09:30" so as long as you're travelling after 09:30 it's valid on any train outward or return. Therefore you'd be fine using the 1707 or 1732 :)
You can find the restriction code text here.
Looks like you have restriction code W1, where peak is 0430-0930 in either direction.
So it doesn't matter which train you get after 0930.
Incidentally, I first looked up Abbey Wood to Cardiff, a totally different journey (with no off-peak day return!).
Plenty of scope for confusion there!
AstowJ
30 Dec 2022
Bristol
Oh brilliant! So off peak day return can mean the outbound and return can be used flexibly?
How wonderful! Thanks for your help
Yes it's a flexible ticket. It will be sold against an itinerary but that's a suggestion. As long as you comply with the time restrictions on this ticket you can use any train.
