With the current political uncertainty, there are increasing voices from politicians to cancel HS2. Whether you are pro or anti HS2, alternatives might be back on the agenda. So what is the business case?
Is it speed or capacity increases that are required on the rail network?
Could anyone hazard a guess at the cost of the following package?
- Electrifying Marylebone to Birmingham (infrastructure and rolling stock)
- Reinstate St Pancras to Manchester and fully electrify MML to Sheffield, Manchester and Leeds
- Reinstate and fully electrify the Woodhead route
- Electrify Birmingham to Reading and Heathrow
- Southern access to Heathrow
- The complete reopening of the Waverley route to Carlisle
You'll find answers to some of these questions in the work done by Atkins back in 2010; see:
https://webarchive.nationalarchives...ail/alternativestudy/pdf/strategicoutline.pdf
Regarding the former GW&GC Joint through the Chilterns, much of this was built in the early twentieth century with four-tracking in mind, and Atkins identified a possible route which would bypass the
"bendy bit" through High Wycombe and Princes Risborough; some of this would be in tunnel. Consequently, as much of the land needed for four-tracking is already in Network Rail ownership, much of the route between Old Oak Common and Ashendon Junction could probably have been upgraded using powers comprised in the original Act of Parliament for construction of this line.
Obviously, this wouldn't give the speed benefits HS2 will bring (although Atkins determined that, based upon alignment, very high speeds were theoretically possible upon much of the GW&GC Joint), it could have been a less contentious route through the Chilterns, and therefore should have generated less hostility from those who live in the area.
At the time Atkins did their work for the 2010 published report, it would also have been possible to use the trackbed of the GC from Ashendon Junction northwards to near Brackley, and then to follow the route proposed for HS2 northwards towards Birmingham and the Trent Valley. Alternatively, it could have followed the GC to a junction with the WCML in the Rugby area; BR considered this section of the GC main line as part of a
"new" route to the north west when it looked into creating high speed relief for the WCML round about 1990.
Somewhere in the Atkins report it states that the remit it received from the DfT prevented it from looking into the possibility of re-opening closed lines such as the GC; whether or not this restriction prevented it from considering restoring short missing sections, such as Woodhead and Peak Forest, I don't know, but you won't find any reference to them in Atkins work (if I remember correctly)
