Rishton to Guiseley Permitted Routes
rishtonlad
26 Jan 2012
Would an off peak return routed via Burnley be permitted to travel from Accrington to Todmorden to change there for services towards leeds.
Yes you can travel via Todmorden and Leeds (using Blackburn and Leeds as routeing points, and using map NP).
(Booking engines do not need to even check the maps if you change at Todmorden and then do the walk through Bradford, as that would be shorter than the shortest route by rail)
It is coming up I just want to make sure
Good to see we are trusted more than NRE :)
