Routing of Ellesmere Port-Warrington 'Any-Permitted' return
ATW Alex 101
28 Dec 2010
Ellesmere port
Hi folks,
I was wondering if I purchased a Child Ellesmere Port-Warrington Anytime Day Return with the route 'Any-Permitted', could I use this to travel from Warrington to Crewe then to Chester then break my journey at Capenhurst?
I had a look on trainscanbecheaper but I find it a little hard to navigate. I assume that going via Crewe may not be possible, but it saves me an hour or so wait at Warrington. This may sound absolutely bonkers but is there some sort of excess I could buy? Maybe a change of route? I understand that there is some potential challenges in buying excesses and I should really try to avoid setting out to buy them.
Cheers in advance
Hi folks,
TCBC is a tool to interpret the Routeing Guide, the Guide itself is on the ATOC website. You could give our RailUK Fares & Ticketing Guide - Section 3 - Routeing a go, which should help you understand the Routeing Guide. If there's a particular part you are stuck on, let us know exactly which part and we'll try to help.
There is a website which lists all the fares: brfares.com
There is no "Route: via Chester" fare to excess to. The only routeings are "Any Permitted" and "via Liverpool".
A change of route excess, where one exists, costs no more on board so there's no need to be concerned if a ticket office doesn't know how to issue it.
SickyNicky
Verified Rep - FastJP
8 Sep 2010
Ledbury
Hi. Sorry you're finding TCBC hard to navigate. Yorkie is correct that trainscanbecheaper is only an interpretation of the routeing guide, although it is capable of finding out what you asked for.
Go to trainscanbecheaper.info/tt.aspx. Put in "Ellesmere Port" as the "from" and "Warrington Stations" as the "to". In the "Stopping at" section, type in "Chester" and click "Add This". Now click "Click Here to Search for Journeys"
TrainsCanBeCheaper will offer some journeys, but you will see that they are all grayed out. If you click on one of them that looks similar to the journey you want, you can look at the diagnostics at the bottom. In this case, they show that the only maps from Hooton to Warrington are NO and NR, neither of which allow travel via Chester (or Crewe)
If any journey results are coloured green or yellow, they do follow permitted routes. If there were any change of routes excesses available for a journey, they would also come up green or yellow. Because there aren't, you'll probably need two tickets for your journey.
Please let me know if you need any more help using the system, or if you have any suggestions to make it easier to use.
kieron
22 Mar 2012
Connah's Quay
Going by the printed rules (with particular reference to the bit which says Ellesmere Port is associated with Warrington Group), I don't think you'd be allowed to travel via Capenhurst. NRE's secret rules are more generous here, but even then Chester's the furthest you can manage on that ticket.
Capenhurst-Warrington is valid that way (although you can only start in Ellesmere Port on a diesel train), but it's a bit dearer.
