Tom C
- Joined
- 4 Jul 2005
- Messages
- 549
There are two departmental 309s, quite a few 310s and a couple of carriages of a 312
The 309s are not going anywhere, Angel are waiting to see if anyone can use them further.
The AC EMU group have been trying to secure a 309 unit but as you say Angel Trains are keen to get it back on the rails as a departmental but sooner of later Angel Trains will want to get rid so hopefully the AC EMU group will keep badgering until they get it.
Also forgot to mention that a 309 coach is undergoing restoration at Walthamstow Pump House so they are not completely forgotten .
The 312 coaches are owned by a fire brigade [not sure which one], so goodness knows what they will look like after they have finished with them.
There is already a group set up to try and secure the 312 coaches after the fire brigade have finished with them. Not sure how wise that is concidering they are going to be set on fire several hundred times but got to admire them for even concidering it
That obviously means that the rest have been scrapped at Immingham already?
If the units have moved to Immingham does it mean that they can no longer be secured for preservation before they get cut up?
will need seating etc. this is close enough to Intercity 70 seating [only minus the armrests] found in some HSTs and until recently, the CEPs.
Arn't the 1st class seats on 317's the same type?
Sure First will refurbish these sooner or later so it might be worth asking for the old ones?
Not quite, Tom.
At Mangapps near Burnham on Crouch, Essex there are a couple of 302 DT coaches back to back, and these are used fairly regularly.
You are quite right, sorry bout that.
Last time I saw them they were in very faded NSE livery do you know they are planning to freshen up the coaches?
