freelander
regarding the 158 on the Edinburgh- Inverness does anyone know what seating is available in First Class and is it at the front or back of the train or could be any of the two.
freelander
freelander
Because it is booked to be formed of a Class 170 with both classes of accommodationthanks for that, but why does passenger info state "seating first and standard"
Network Rail don't have a journey planner but that doesn't matter; the data will be the same in all systems.and as for pricing I have been quoted for a first class ticket ??? this info is also stated on Network rail planner or Train line
Well quite. On the HML you're at far greater risk of a Standard only 170 turning up than a 158.Because it is booked to be formed of a Class 170 with both classes of accommodation
If a 158 or Standard Only class 170 turns up, 1st class ticket holders will be entitled to a refund of the difference between the 1st and Standard fares.
Bottom line - don't waste money on First Class on Scotrail until the HSTs arrive.
Precisely. In addition to the refund of the difference, if there is catering onboard, they would most likely be offered their complimentary coffee on the train as a goodwill gesture.It's not a waste, because as noted if a unit without First Class turns up on a First Class diagram you can get the difference back.
Contractually yes, but I know someone who has been waiting 8 weeks and hasn't been compensated. (and who also didn't get offered anything from the trolley either)It's not a waste, because as noted if a unit without First Class turns up on a First Class diagram you can get the difference back.
You didn't actually make that point, so I think they can be forgiven.You're missing my point.
