"See Restrictions"
Discussion in 'Fares Advice & Policy' started by trainophile, 6 Jun 2015.
Thread Status:
  1. trainophile
    trainophile Established Member
    3,130
    28 Oct 2010
    I have consulted the Fares and Ticketing Guide on this section before posting this, but all I can find in the section on Off Peak Day Returns is...
    I had such a ticket for Hereford to Birmingham Stns today, with the wording "SEE RESTRICTIONS" under Validity. However I have no idea where the details of said restrictions may be found.
    On my return trip I fancied breaking my journey at Worcester, and asked the guard whether this was allowed, showing him my ticket. He barely glanced at it, and said "of course it is". So that was fine, I got off at Foregate Street for an hour, and back on the next train with no problems whatsoever.
    I just wondered how I could have known what the Restrictions relating to this ticket are, without having to ask. Is such information generally available to the ordinary passenger?
    Rail Forums
  3. TEW
    TEW Established Member
    4,751
    16 May 2008
    It is available quite easily nowadays, but the normal passenger would have no idea how to find it. You need to go to the following webpage:
    http://www.nationalrail.co.uk/xx
    Where 'xx' is the restriction code for the ticket. On most tickets this can now be found printed in small writing next to the words Validity on the ticket. New style tickets are clearer, directing passengers to that webpage to check restrictions.
    For example, for the restriction code 'BE' this is the webpage:
    http://www.nationalrail.co.uk/BE
    An example where Break of Journey is prohibited (a code applied to Off Peak Returns, rather than Off Peak Day Returns) is 8A:
    http://www.nationalrail.co.uk/8a
  4. trainophile
    3,130
    28 Oct 2010
    That's brilliant. My ticket code is DI, which disallows travel on trains at certain times on weekdays but is fine for weekends.
    Thanks you, mystery solved :D .
  5. hounddog
    hounddog Member
    276
    4 Mar 2014
    Nor, indeed, ticket-checking staff at a certain London terminus.
  6. ainsworth74
    ainsworth74 Moderator Staff Member Moderator
    18,149
    Another way of doing it is through BR Fares. For example if I wanted to check the restrictions of a Middlesbrough to Manchester ticket I would go to BR Fares, input my origin and destination, select the ticket I wanted to check (lets say an Off-Peak Return) and it will then tell me the restriction code, the meaning of that code and if there are any break of journey restrictions on that ticket.
  7. yorkie
    yorkie Administrator Staff Member Administrator
    37,211
    Indeed; if holding an Off Peak Return (SVR) or Super Off Peak Return (OPR/SSR), you only need to check for the outward portion, and the restriction only applies on a small number of journeys. The return portion always* allows break of journey. For an Off Peak Day Return (CDR), you don't need to check at all.
    (* I better get this disclaimer in for pedants, though the OP can safely ignore this: there are one or two exceptions in the case of a small number of OPRs set by LM, however it's clearly not enforceable and LM themselves have encouraged passengers to break their journeys regardless!)
Thread Status:
Share This Page
