Raul_Duke
- Joined
- 29 Mar 2014
- Messages
- 396
Sheffield must also be due for a remodel. Very much set up for steam / LHCS, like the old Derby was.
Indeed, but that will come from the HS2 budget, including restoring a 3rd track south and west down the Sheaf valley fromDore - dreaming on. Quite how the north and east approaches can be improved is a big challenge but it's long been accepted that any elecrification will require a total remodelling.
As for the south, bring back the dive-under!!!
Essentially, the design meant that the London lines principally served platforms 1, 6, and 8 and the Manchester lines 2 and 5, thus bringing down trains from London to the North into the long main platform on a level with the station entrance. 1 and 2 were the new through platforms added during the station rebuilding. By the standards and for the services of the time it was a thoroughly well planned and up-to-date layout. And the Midland Railway did have plans to complete the Sheffield-Masbrough quadrupling by dealing with the section between the station and Mill Race Jn.The “dive under” was between Heeley and Midland station. The carriage washer stub line is all that is easily visible. The four tracks between Dore and Sheffield were paired into up/ down fast, and up/down slow. The “dive under allowed fast line access to low number platforms whilst not impeding slow trains. There aren’t four tracks now south of Sheffield.
To install a “dive under” at Dore would not be feasible as it would be filled up by the adjacent River Sheaf which runs next to the railway!
From google maps quadrupling north out of Sheffield to the junction for the Worksop line wouldn’t be that difficult - empty land, a handful of tatty old buildings, and mainly redundant bridges.
Getting under the A57 might be disruptive, then it looks relatively clear if you are prepared to build a new parallel viaduct for a couple of miles. If you could afford to take the fasts over the top of Meadowhall Interchange then you could have fast lines on the west side straight through from Dore to Rotherham where the slows would peel off to go through Central (I refuse to accept that one supermarket should prevent quadrupling from Dore to Sheffield!!)
There was a bay the the northern end of 8 — that's why it's further from the wall at that end.Maybe you could cut a hunk out of platform 8b to accommodate a three/four coach unit in a bay platform? It'd mean knocking the old stand-alone building down (between the northern end of 6/8) but the track through 8 looks like it could be better skewed against the wall (of the embankment that the tram runs on), so it feels to my untrained eye that there may be space for a terminating platform there whilst keeping sufficient platform face at 8 to accommodate a ten coach 804 if need be?
Splitting P1 would create two bays of about 4-car length. But taking up one through line doesn't create enough space for a platform up against the other through line, even if it would only be a one-sided island with a fence down the back. Moving the P2 platform edge eastwards to widen this gap would probably destroy one of the north end bays, and P2 isn't especially wide anyway for a major city station. Similar issues would arise in trying to use the other through lines between 5 and 6.As a passenger, I find Sheffield Midland quite a good station to use - plenty of cover and facilities, and nothing too out of the way and difficult to get to (with perhaps the exception of the bay platform used by the Hope Valley stopper.
If there is a shortage of platform space, would it be worthwhile doing something similar to the work done at Gravesend recently. You could turn platform one into fairly long North/South facing bay platforms, and in the centre extend it out to give level access to a new long through platform on the site of where the down through line currently is (with the up through becoming the platform line).
I think to create an extra long platform within the existing footprint would involve demolition of one set of island buildings to replace that island with a narrower one, so as to widen the space occupied by two through tracks enough to make a one-sided island against the remaining through track.
I’ve been using Sheffield station daily for 17 years, it was only recently that I first saw that headhunt used.
I know when they relayed the points at the north end a few years ago they were replaced like for like because otherwise they would have to have resignalled, yet the headshunt off platform one hasn’t been used for decades.
andGrade I buildings are of exceptional interest, only 2.5% of listed buildings are Grade I
Grade II* buildings are particularly important buildings of more than special interest; 5.8% of listed buildings are Grade II*
Grade II buildings are of special interest; 91.7% of all listed buildings are in this class and it is the most likely grade of listing for a home owner.
How will listing affect me?
Listing is not a preservation order, preventing change. It does not freeze a building in time, it simply means that listed building consent must be applied for in order to make any changes to that building which might affect its special interest.
What can I do with my listed building?
Listed buildings are to be enjoyed and used, like any other building. Listed buildings can be altered, extended and sometimes even demolished within government planning guidance. The local authority uses listed building consent to make decisions that balance the site's historic significance against other issues, such as its function, condition or viability.
It is extremely unlikely the council would grant permission for their wholesale demolition.
Interesting that the Council is insistent HS2 is accommodated in Sheffield Midland! Something will have to give if HS2 is to be routed to Sheffield.
If you keep locals on the East side you could build a new fuelling/stabling site on the Sheffield council Olive Grove Depot less than a mile south of the station
The east island is already 385m long over its furthest ramp extremities and the west island is only marginally shorter.
It's frustrating that we have five very long platform faces when so many of the services at Sheffield are only two/three coaches long - other than the hourly "fast" London service (7x23m) and a couple of XC HSTs per day, most services could fit into a typical bay platform at a typical station!
Probably not going to a problem, as given the cost escalation to over £100bn HS2 is unlikely to get much beyond Birmingham and a link into WCML. Anyway east - west connectivity is much more important to the North of England than getting to London quicker.
If you quadruple to the new depot and northern use the east island (double stacking every other train) then long distance has free access from the south to 1,2, and 5.That's an interesting idea - if all "local" services could run through to terminate there (even if no station opened, just a maintenance facility) then that would free up a lot of platform space - given the numbers of Huddersfield/ Leeds/ Adwick/ Doncaster/ Retford services terminating each hour. Nice
