YourMum666
Should there be a Heathrow - Bham rail link constructed for Hs2, it would run as a loop (Euston - OOC - A remodelled Heathrow Central - Join back with HS2). Is this practical and cost efficient and is it justifiable
It was part of the initial plans and found to fail all three tests. With the existing subterranean infrastructure at Heathrow it would have been a vastly expensive exercise with many sub-optimal design compromises even if a legally compliant route (for evacuation) could have been found.Should there be a Heathrow - Bham rail link constructed for Hs2, it would run as a loop (Euston - OOC - A remodelled Heathrow Central - Join back with HS2). Is this practical and cost efficient and is it justifiable
No. It was investigated and ruled out. There was not enough demand and obvious time penalties compared to direct trains. It’s been discussed numerous times before.Should there be a Heathrow - Bham rail link constructed for Hs2, it would run as a loop (Euston - OOC - A remodelled Heathrow Central - Join back with HS2). Is this practical and cost efficient and is it justifiable
Stop being so grown upIt was part of the initial plans and found to fail all three tests. With the existing subterranean infrastructure at Heathrow it would have been a vastly expensive exercise with many sub-optimal design compromises even if a legally compliant route (for evacuation) could have been found.
If you want my free-thinking idea it involves building a 4-runway airport to the North of London to avoid overflying, but connected to the M1, M40, WCML, HS2 and Chiltern lines. Closure of Luton and Heathrow with the new London Cotswolds international having a big low-cost terminal alongside it's main int'l stuff.Stop being so grown up
As mentioned, the need for new tunnellig ultimately kills the idea everytime, especially when considering the need to either go under or round several suburbs.
As also mentioned OOC provides enough of an interchange, although it may well kill the BA Shuttle longer term, despite it already being a shadow of it's former self
It would also be funded by building 1 million houses on the former Heathrow and Luton sites
I think there may be bigger problems trying to find a site for 4 runways in the Cotswolds before you even start thinking about what you might do with Heathrow...If you doubled the typical maximum density of homes usually found in the densest parts of London, you might get 400,000 homes on Heathrow, and a quarter of that on Luton. But that would be without any other facilities - schools, healthcare, retail, or anywhere else where people might work.
This kind of airport would be best served by an underground station below the terminals. So it could just go above the under-construction Chiltern hs2 tunnelIf you want my free-thinking idea it involves building a 4-runway airport to the North of London to avoid overflying, but connected to the M1, M40, WCML, HS2 and Chiltern lines. Closure of Luton and Heathrow with the new London Cotswolds international having a big low-cost terminal alongside it's main int'l stuff.
It would also be funded by building 1 million houses on the former Heathrow and Luton sites, with associated business and retail development for several new 15-minute cities. I often have fun imagining the screech of pearls being clutched by the great and good of Oxon & Bucks![]()
I know it may have been done as a joke, but I cannot see London Cotswold airport happening, as there is enough complaints about where HS2 is being built and how it is ruining the countryside.If you want my free-thinking idea it involves building a 4-runway airport to the North of London to avoid overflying, but connected to the M1, M40, WCML, HS2 and Chiltern lines. Closure of Luton and Heathrow with the new London Cotswolds international having a big low-cost terminal alongside it's main int'l stuff.
I really doubt that people would be willing to travel on London Underground that far out to get to an airport! It takes a class 8xx about an hour and half to get from say Moreton-In-Marsh to London Paddington, how long would it take an Underground train from London do you think?This kind of airport would be best served by an underground station below the terminals. So it could just go above the under-construction Chiltern hs2 tunnel
I'm clearly going to have to make it clear when I'm being more than slightly sarcastic, although it does raise an interesting question about the nature of some proposals we get on here.I know it may have been done as a joke, but I cannot see London Cotswold airport happening, as there is enough complaints about where HS2 is being built and how it is ruining the countryside.
underground, not Underground. It would be a mainline station but just built in a massive concrete box/trench underneath the airport, as commonly seen at many (most?) major European airports including Heathrow.I really doubt that people would be willing to travel on London Underground that far out to get to an airport! It takes a class 8xx about an hour and half to get from say Moreton-In-Marsh to London Paddington, how long would it take an Underground train from London do you think?
It's just the nature of this particular subforum.I'm clearly going to have to make it clear when I'm being more than slightly sarcastic, although it does raise an interesting question about the nature of some proposals we get on here.
Birmingham gets it's station because it's part of the Birmingham Interchange complex, including the NEC, ability to function as a P&R site, and offering greater connections in and out of HS2 that allow passengers to avoid changing at New Street (to many passenger's relief no doubt). They've also dug most of the holes for Birmingham Interchange now so it's going to be built.I'd assume the reason why Birmingham still has an airport HS2 station (at time of writing!!) and Manchester was intended to and may still get one is to provide more airport capacity for London and the South East without having to make any difficult extra runway decisions rather than as an alternative for people flying into Heathrow and using BA's shuttle to fly to Manchester.
I doubt people will look much further than their normal airport unless airlines start aggressively pursuing codeshare agreements with the HS2 operator. The Airports are simply convenient hubs for people heading into a different city centre, they are going to have a negligible impact on air traveller patterns, I fear.Perhaps HS2 will provide people from the usual catchments of all three major airports served with more reasonable options for flights to use, so for example someone from the southeast may be able to pick up a more compelling price level/departure slot for a particular journey from Birmingham or Manchester airport that they might not have considered otherwise without the fast train journey to get there. This could also help airlines fill long-haul seats that might otherwise not be sold, which, for a flight that is going to take off anyway, could be considered an environmental as well as a commercial benefit for them.
