moggie
Moderator note: Split from https://www.railforums.co.uk/threads/possible-hs2-euston-station-de-scoping.213574/
Lots of valid opinion so here's mine! We all know that the proposal to remove a platform from the core design of Euston HS2 is to save money. Fine if that's the publicly declared and the intent and consequence is published. But pretending the current operational specification (in so far as it exists for the planning and design of the station up to now) will not be compromised is clearly nonsense. The current design for 11 platforms meets the required performance specification and the projected timetable to ensure a specified level of reliability, including the capability to absorb a specified degree of perturbation. There won't be any 'padding' within the spec, or the design which satisfies it as this will already have gone through a fine toothcomb to remove unnecessary bloat.
Therefore if 10 platforms is now the build target to save on cost then it follows that the operational specification including the capability to absorb a degree of service perturbation will have to be changed (reduced) to cater for either a reduced service, less ability to absorb service disruption of more services subject to cancellation or terminating short of destination (Euston). No wrapping the subject around lots of technical and commercial complexity changes that. What boils my <> is the attitude that a project costing £BN's etc is already being saddled with permanent operational compromise before they've even started and which ultimately stands to fail it's customers more often than would otherwise be the case. As if the critics of the project didn't already have enough bile to spray!
Personally I'd save some of the the planet, literally, and dig less tunnels!
