Something most unusual just happened. The 7.54 Guildford non stop to Waterloo stopped additionally at Surbiton, Wimbledon and Clapham Junction.
I wonder if it switched to the slow lines to do that?
I actually would have preferred to get out at Clapham Junction as I'm going to Twickenham today but as I was due to catch the 8.03, as that was more likely to have seats, I was unaware of what would happen and I wasn't even ready.
I'd also have quite liked the idea of being on a train with an unusual stopping pattern for the time of day it's running.
What will now happen is that I'll probably miss my Twickenham service and arrive late. Such is life.
The 7.36 and it seems possibly 7.58, from Guildford to Waterloo were cancelled so had this not stopped at Clapham Junction, the gap for passengers would have been 1 hour and 25 minutes, not that that would be a reason to stop at Clapham. Thus would have been done for Surbiton and Wimbledon passengers, although even then I'm surprised they did it.
http://m.journeycheck.com/southwest...=&savedRoute=false&incidentsType=LINE_PROBLEM
Sent from my SM-G925F using Tapatalk
Not impressed. Got into Waterloo about 8.57. Had tried to look on Real Train Times to see what might be happening but not enough O2 reception as I headed into Waterloo and being a busy SWT service no on board WiFi working. So I decided to check the station departure boards.
Went to subway but the first train showing for Twickham was 9.03. I then made a he fatal error of checking the National Rail Enquiries App once on the platform for the 9.03. It showed an 8.58 to Windsor was 3 minutes late but no platform due to Darwin upgrade.
As I knew some other trains had been cancelled I thought I'd ask to be safe. I wanted to catch it, as it's faster.
In the mean time the 8.58 switched to showing as delayed.
So I asked a member of staff who said catch the 9.03 by this point the 9.03 was departing.
Then I checked Real Time Trains and found the 8.58 left 6 minutes late and I could have caught it, if only I'd checked that web site. I even saw the train on the platform earlier but I couldn't be certain it wasn't an empty coaching stock service. I did not wish to end up in a siding.
It seems not good that they remove trains from the board when they are delayed.
I had to catch the 9.20 and I will be half an hour late to my destination.
Does anyone know when Darwin is live with South West Trains. Last I heard was early April but they have removed that message from SWT Journey Check and not replaced it with anything else. Originally it was due last October. I'd love to know what problems they are facing. Must be lots of unforseen technical issues with the systems used.
Anyway end of rant. I'll get over it. Far worse things could happen than this.
Cancellations to services between London Waterloo and Surbiton
Following a signalling problem between London Waterloo and Surbiton some Main Suburban lines are now open.
Impact:
Train services running to and from these stations may be cancelled, delayed by up to 30 mins or revised. Disruption is expected until 11:00 12/04.
Customer Advice:
A signalling problem at London Waterloo meant that trains were unable to run from platforms 1 - 4. The fault is now fixed but the platforms were closed for over 1 hour. The disruption this has caused will affect customers travelling to and from our suburban destinations, including Wimbledon and Surbiton.
Short notice cancellations and alterations are expected. All alterations will be available to view at www.journeycheck.southwesttrains.co.uk
Services between Shepperton and London Waterloo will be diverted to run via Twickenham calling additionally at Strawberry Hill and then non-stop to Clapham Junction.
Valid rail tickets will be accepted on London Buses on reasonable routes between Waterloo and Surbiton and on London Underground services.
If you hold a South West Trains ticket you can use Southern Rail services between London Victoria, Clapham Junction and Epsom & Dorking. You should expect a journey time of between 30 and 50 minutes for this route.
The following routes have been altered, but begin to return from approximately 09:00
- London Waterloo to Hampton Court - first train from London will be 09:06, from Hampton Court at 09:53
- London Waterloo to Shepperton The first train from London via Kingston will be 08:12, the first train from Shepperton via Kingston will be the 08:10.
- London Waterloo to Salisbury. The first train from Waterloo will be the 11:50 to Salisbury, the first stopping train from Salisbury will be the 08:47.
The following routes will be subject to delays and possible short notice alteration:
- London Waterloo to Dorking
- London Waterloo to Guildford via Epsom/Cobham
- London Waterloo to Woking (stopping services)
- London Waterloo to Chessington South
- London Waterloo to London Waterloo via Kingston
We are sorry for the disruption to your journey this morning.
Additional Information:
For more information about track circuit failures and signalling problems and what we're doing to reduce them, please see Delays Explained here: http://www.networkrail.co.uk/timetables-and-travel/delays-explained/track-circuits/
If you would like to make a comment or give us some feedback about your experience with us today, please email us at [email protected], 0345 6000 650 (option 4) or fill in the contact us webform http://po.st/ContactSWT
Have you been delayed by over an hour ? Please see here for information about compensation - http://po.st/SWTCompensation
Message Received :12/04/2016 08:38
