Single wheelers
Discussion in 'Railway History & Nostalgia' started by StirlingRatty, 4 Mar 2017.
Thread Status:
  1. StirlingRatty
    StirlingRatty Member
    7
    19 Jul 2016
    I am trying to understand the reasons for the move from large single wheel locomotives to multi coupled ones. What was the technological advance that caused that move?
  2. Elecman
    Elecman Established Member
    1,090
    31 Dec 2013
    Lancashire
    Increasing train weights meaning the single wheelers were unable to start the loaded trains due to lack of available adhesion
  3. Flying Phil
    Flying Phil Member
    353
    18 Apr 2016
    Would improved lubricants/lubrication also have enabled higher piston speeds, thus enabling smaller (coupled) driving wheels to rotate faster for higher speed?
    I did see the Stirling Single on the GCR years ago and it was so effortlessly elegant - but only on a three/four coach train!
  4. Taunton
    Taunton Established Member
    2,470
    1 Aug 2013
    One technological advance was improved steel for coupling rods, which previously had been too prone to failure with higher power transmitted, due to the stresses they sustain at the joints (more so than connecting rods).
  5. 70014IronDuke
    70014IronDuke Established Member
    1,428
    13 Jun 2015
    Surely the fundamental reason was economic, rather than technical as such.
    for reasons of economy, you wanted ever bigger locomotives to producethe power to pull heavier loads (and/or faster).
    The crew of two remained the same, plus the guard. So obvoiusly, it was cheaper to run one big loco + (say) 10 coaches, than two trains with smaller locos and 5 coaches. (Or maybe 6 coaches, as two would be BSKs :) )
    But, you simply could not build a 70 tonne locomotive and put it on one pair of driving wheels - either the axle loading would be so much it would break all the rails and bridges, or, if you used unpowered axles to spead the load (eg into a 4-2-2 arrangement) you lost adhesive weight - ie your single driving axle would be VERY prone to slipping.
    The only solution was to expand the number of driving wheels/axles, initially to x-4-x arrangements, and later to x-6-x, x-8-x and even (in the UK) to 2-10-0s.
    But it's like every system known in the universe: you develop some aspect to maximise its particular performance, only for other limiting parameters to take effect - eg as noted about, the coupling rods failed (for a period) or, eg the poor fireman was unable to shovel in enough coal to feed the massive grates needed to utilise the massive boilers etc etc
  6. EveningStar
    EveningStar Member
    31
    11 Jan 2016
    Alnmouth for Alnwick
    Midland Railway did not get that memo!:roll:
  7. Wilts Wanderer
    Wilts Wanderer Member
    444
    21 Nov 2016
    Probably why the LMS based their motive power engineering department in Crewe not Derby!
  8. edwin_m
    edwin_m Veteran Member
    10,992
    But still heavily influenced by Derby practice until Stanier arrived in the early 30s.
  9. EbbwJunction1
    EbbwJunction1 Member
    697
    25 Mar 2010
    "M is for Midland with engines galore
    Two on each train and asking for more!"
  10. Bevan Price
    Bevan Price Established Member
    3,037
    22 Apr 2010
    No - but even Midland Railway found it had to replace single-wheelers by 4-4-0s.
  11. MarkyT
    MarkyT Established Member
    2,001
    20 May 2012
    Torbay
    While the widespread need for double-heading in steam days made little sense on the LMS, and its BR successor region, the original Midland Railway offer of comparatively short trains departing often from St Pancras was perhaps an early example of a company recognising the attractions of high service frequency to customers.
  12. edwin_m
    10,992
    I still don't understand why the Midland didn't build bigger engines, at least when they got far enough north that the routes were hilly and I believe most trains needed double heading. It's not as if Derby couldn't build large locos, as they did for the S&D.
  13. MarkyT
    2,001
    20 May 2012
    Torbay
    One explanation as to why the rival GNR and successor LNER always built locos able to handle the largest trains singlehandedly was a long held understanding that there was a 'ban' on double-heading by the civil engineer on lines into Kings Cross. After the end of steam, my father, who was by then the local divisional traction and rolling stock engineer, wanted to investigate the truth behind this apparent 'ban' as part of the research for his book about the LNER pacifics. There was no formal documentation of the restriction in any sectional appendix or other publication he could find, so what was its source? Informal approaches to friendly colleagues in the the civil engineers resulted in bridge inspectors being dispatched to carry out detailed investigations of the Welwyn viaduct and a bridge at Newark, believed to be the problem structures. From these enquiries, the civil engineer concluded there was in fact no substance whatsoever to any supposed restriction! Double heading then came in very useful as a method for ferrying deltics, working in multiple, between London and Doncaster for the routine engine swaps that were part of the maintenance regime for the class.
  14. Taunton
    2,470
    1 Aug 2013
    Gerry Fiennes, in "I tried to Run a Railway" commented on this; when the Deltics were under consideration to replace the lower powered pioneer diesels which didn't have the performance, another senior manager said "Why don't you double-head". And that was where the restricted length of Kings Cross station (which it has compared to other termini) came into play. Fiennes, the Deltic champion, retorted "yes, two locomotives on EACH end with a platform turnround, triple-car dining set (which the ECML long had), and you end up with space left for about three coaches".
    Certainly during WW2 when maximum train lengths were required it was not uncommon apparently to have four or five coaches off the platform there, and the train engine actually just into Gasworks Tunnel, all blocking much else.
  15. 70014IronDuke
    1,428
    13 Jun 2015
    You have saved me writing the same thing (more or less). The London extension in particular needed this kind of service - and still does to some extent today. Very different population centres north of Luton compared to, say, the ECML, where you only really had Huntingdon and Peterborough north of Hitchin pre 1970. I remember when the local service north of Hitchin was incredibly poor in the early 60s - one four-car DMU every four hours, plus two up and two down commuter trains to/from KX in the peak.
    But going back to the original point, although compounds were quite big locomotives when first introduced, the Midland surely could have used a decent Class 5 type 4-6-0 on the difficult routes such as Peak Forest and the S&C.
Thread Status:
Share This Page
