SJ X2000 Tail Lights
Kurolus Rex
1 Mar 2019
Hi there!
Does anyone know if the tail lights on the X2000 flash?
I've seen other trains in Sweden with flashing tail lights (such as on LHCS stock) but on videos of the X2000 I've seen they don't appear to flash. I queried this with a Swede and they said that it was normal for tail lights to flash in Sweden but i'm wondering if there's an exception with the X2000 or not.
Also, on a related note, I've noticed that the DVT (or whatever term is used by SJ) usually uses the lower cluster of lights for the tail lights whilst the locomotive uses the upper cluster. Is there a reason for this?
Any info on this topic is greatly appreciated!
JonasB
27 Dec 2016
Sweden
They did flash when the trains were new, tail lights (except on locos) have traditionally been flashing in Sweden. I'm not sure if has been a requirement or if it just has been a way of making the batteries last longer. But now most (if not all) have been rebuilt with non flashing tail lights. Probably because when the relays controlling the flashing breaks, it has been easier to just remove them. An interesting side note is that they were the first swedish multiple units delivered with the tail lights and head lights in the same cluster, as the requirement for the tail lights to also have white light forward had recently been dropped.
Originally all tail lights where in the upper cluster. But some of the control cars/driving trailers, whatever you want to call them (SJ designates them UB2X) has had them moved. I'm not sure how many has has them moved and if it is a permanent change or if it has been a test of new headlights for the big refurbishment of the X2000s.
Flashing lights:
Steady lights:
Kurolus Rex
1 Mar 2019
Flashing lights:
Steady lights:
Thanks for the info!
jamesontheroad
24 Jan 2009
Thanks also for the info JonasB.
What is the current status of the 'big' X2000 refurbishment? Have any units been started or finished?
jamesontheroad
24 Jan 2009
Here's another Swedish observation, sory of related... from a driver's cab ride video, it appears that Öresundtåg drivers can flash their headlights in a familiar sign of greeting one another. See this video at 1:35 as we pass a stationary train awaiting a platform at Alvetsa.
Jamesrob637
12 Aug 2016
Loved the X2000 on a journey from Stockholm to Katrineholm in 2006. Sadly I didn't travel X2000 when I revisited Sverige in 2010 and I haven't been for the near-decade since
JonasB
27 Dec 2016
Sweden
Yes, all locos and MUs are required to be able to flash their headlight, it is used as a warning signal in emergencies. But this looked like the regular high beams.
TRAX
2 Dec 2015
France
this is also a popular habit in Germany and surrounding countries.
