Southern & Gatwick Express (again)
dvboy
6 Sep 2011
For those who haven't been keeping up on the SN/GX threads... back in January I approached gateline staff at Victoria and asked if a Southern Only Off Peak Day Return was good for the Gatwick Express, and was sold a "Southern Std Su" upgrade ticket, pictured on the right here:
http://www.railforums.co.uk/attachment.php?attachmentid=10104&d=1328977770
Mid-February I wrote to Southern requesting a refund having since learned that Southern and Gatwick Express are not seperate companies, and therefore the Southern Only ticket should have been allowed because it is a breack of NRCoC 10 to restrict a ticket by anything other than company or route.
Yesterday I received a letter from Southern stating that a member of the Refunds team will contact me by telephone to obtain my card details in order to process the refund.
hairyhandedfool
14 Apr 2008
It must be said that CR departments often break (or at the very least bend) the rules to give "good customer service", I wouldn't take this as concrete evidence of anything.
wintonian
15 Jan 2010
Hampshire
Agreed, unless they have admitted that the original ticket was valid in writing pen & ink style.
ralphchadkirk
20 Oct 2008
Essex
Quite. It does not set any kind of precedent.
Sent from my iPhone 4 using Tapatalk
dvboy
6 Sep 2011
Unless perhaps they've actually admitted to being in the wrong in the letter?
I suspect it probably doesn't.
They haven't, and they haven't phoned yet either (although I'm not sure I gave them my number so I think they will write again).
island
30 Dec 2010
What is the cheapest ticket to travel one-way, today, from Gatwick Airport to Lee (London)? How about the fastest journey?
(In case you're a "helper" at the TVMs at Gatwick Airport station, a hint: it definitely isn't getting the Gatwick Express to Victoria, LU Oyster to London Bridge, and Oyster on Southeastern from there.)
SickyNicky
Verified Rep - TrainSplit.com
8 Sep 2010
Ledbury
The cheapest and fastest is probably an FCC to London Bridge and change there. You would have to touch in at East Croydon (are there platform validators there?) or buy a paper ticket, which is rather more expensive.
GATWICK AIRPORT to CROYDON STATIONS
ANYTIME DAY S
£5.00
Route: FCC ONLY
CROYDON STATIONS to LEE (LONDON)
OYSTER OFF-PEAK
£2.80
If the Gatwick "helpers" are suggesting via GX, I would be tempted to complain.
island
30 Dec 2010
No platform validators at East Croydon, so you have to get off and get on the next train, or use a paper ticket (£5.30).
Your way is even cheaper than the one I ended up using, which was a Gatwick Airport to London Zones 1-6 ODT at £12.50, although it turned out we needed to make more journeys later so it turned out fine in the end.
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
Cheaper than going via London Bridge is to change at East Croydon onto a stopping service as far as New Cross Gate, then walk to New Cross to pick up a train to Lee. That would be £2.10 off-peak on Oyster, saving a further 70p.
I wouldn't expect these "helpers" to suggest any split tickets at all, when a through fare is available.
It may be worth making some enquiries to establish whether they are required to act impartially, whether they believe they were acting impartially (!), and if they are allowed to not be impartial then to what extent are they allowed to be biased in the favour of one particular TOC?
Clearly the FCC only ODT at £12.50 is the cheapest ticket, so this should be offered.
I would advise writing to ATOC, Southern, FCC and Passenger Focus about this issue.
In particular I would expect FCC to be interested, as a member of railway staff attempted to get a customer to travel by a slower, and more expensive combination of tickets, than a through ticket with a straightforward change at London Bridge.
Madness. I can't believe Southern (masquerading as a now-defunct TOC) are acting in this way and still getting away with it!
londonbridge
30 Jun 2010
Yep,no validators and there wouldn't be time to run to the gateline to swipe and back (although if you wanted to try it you'd need to be in the last carriage in order to stop closest to the ramp).
Wolfie
17 Aug 2010
May be a silly question, and I know it involves several changes - but if you had any volume of luggage might still be easier - but could you not change at New Cross Gate, Surrey Quays and New Cross as necessary? Cost I guess would be the same.
Paul Kelly
16 Apr 2010
Reading
You could on a paper ticket routed "NOT VIA LONDON". I seem to remember an issue about there being no pink oyster validators at Surrey Quays, so the Oyster system assumed you had gone via London Bridge if you didn't touch out/in at New Cross Gate/New Cross. Don't know if this is still current.
dvboy
6 Sep 2011
Back to my original post and still nothing from Southern. I may write in reply to ask if they have agreed a refund and how they propose doing this.
MikeWh
15 Jun 2010
Crayford
Yes, the problem still exists at Surrey Quays. However, if you go one stop further to Canada Water and touch the pink validator then it will work.
island
30 Dec 2010
Very interestingly, the TVM transaction has just posted to my online banking with merchant name "GATWICK EXPRESS, CRAWLEY"!
MarkyMarkD
1 Dec 2009
Cliftonville, Margate, Kent
... but as I'm sure you (particularly) know, the name shown on bank statements for card transactions don't have to reflect the merchant's legal name.
"Subway" is really called "Doctors Associates" or something strange like that, but bank statements show "Subway".
island
30 Dec 2010
That is true, but most other TOCs I've used have the legal name (London and Southeastern Railway Ltd., West Coast Trains Ltd., and so on).
